Yan2947's Avatar
Mating 930 tranny to engine question
Does anyone have any video on how to mate the 930 tranny to the throwout bearing? I’m a newbie to that and just wanna see a step-by-step or video. It was easy to separate, but I need to put them back together. Just wanna see how the fork gets pushed onto the throwout bearing..
Thank you!
Yan
1989 911 LS1
Old 12-07-2025, 01:15 PM
Look through the hole on top of the bellhousing as you mate the trans to the engine. Set the bearing with the ears at 6 and 12 o'clock first. Use a mirror and flashlight if the trans is still in the car.
206 637 4071
Old 12-07-2025, 01:32 PM
Ryan_Cunningham's Avatar
I don't have a video, but I recall it being very finicky. Like John said, a flashlight and mirror helps.
"Purists are the Karens of motorsports.
IG - Iron_Dad_Moto
1972 Porsche 911 - Long Term Project. 3.6TT/G96.50
1981 Porsche 911SC - In Progress.
F/A-18C/D, F-15C, F-35B/C
Old 12-07-2025, 02:06 PM
Yan2947's Avatar
Thank you so much. Tranny is out of the car so it should be easier. So start at six and 12 o’clock and push the fork onto it. Do I then turn it to three and 9 o’clock?
Yan
1989 911 LS1
Old 12-07-2025, 03:00 PM
No, the fork locks the bearing in place once it's behind it.
206 637 4071
Old 12-07-2025, 05:41 PM
A930Rocket's Avatar
Mating the transmission to the engine, seems to be one of those tasks, that either goes on correctly, the 1st time or the 50th time.
As you pull the two together, the clutch fork will pivot into the correct position.
As mentioned, you can look in through one of the bellhousing gaps, to make sure it’s installed properly
Old 12-07-2025, 05:44 PM
Yan2947's Avatar
Thanks, John and Ryan and A930rocket. I think I understand and I appreciate it.
Yan
1989 911 LS1
Old 12-07-2025, 06:11 PM
Yan2947's Avatar
Does this look like the fork is correctly attached to the throwout bearing?
1989 911 LS1
Old 12-19-2025, 07:09 AM
Appears to be.
206 637 4071
Old 12-19-2025, 07:26 AM
Looks correct.
IG - Iron_Dad_Moto
Old 12-19-2025, 08:10 AM
Yan2947's Avatar
OK, thank you for all the help. Really appreciate it.
1989 911 LS1
Old 12-19-2025, 09:08 AM
