Purpose of hooks under cowl?
I'm replacing the cowl on my 71 and I can't figure out what these hooks under the cowl on the driver's side are for. Anybody know?
Old 12-10-2025, 02:37 PM
HarryD's Avatar
They are to hold the little square evaporative emissions box.
The location can be seen here is post #1. Item 1 of the drawing is the box. It it held in place by a square rubber band. https://forums.pelicanparts.com/porsche-911-technical-forum/481800-fuel-evaporation-emission-system-71-911t.html
This thread can be helpful as well. https://forums.pelicanparts.com/porsche-911-technical-forum/745263-fuel-expansion-tank-bleeder-longhood.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-10-2025, 02:46 PM
Amazing, thank you!
Old 12-10-2025, 02:54 PM
PCA Member since 1988
Harry nailed it. while you're in there, make sure the plastic box is in good shape. Mine had a crack in it that was causing strong fuel smell in the car.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-10-2025, 09:14 PM
