3.2 rising or hunting idle
Once in a whikle my Idle rises higher than normal but not always, Any suggestions, could this be Vacuum leaks, Idle Control Valve or. Throttle not fully closing?
Old 12-16-2025, 09:32 AM
When this happens, it could be the idle switch on the throttle body that is not closing. This can be adjusted.
Gilles
RoW 88 Carrera coupé
Old 12-16-2025, 10:06 AM
proporsche's Avatar
little info for you to check ..
1985 911 with original 502 191 miles...808 198 km
Old 12-16-2025, 11:37 AM
Thanks, I'll try it
Old 12-16-2025, 08:22 PM
Jeff Alton's Avatar
Throttle switch, ICV, base mixture issue or vacuum leak.... could be any of them.
Cheers
www.turn3autosport.com
Old 12-16-2025, 09:56 PM
Also; replace the O-ring on the idle screw, this can be a source of air/vacuum leakage.
Ant.
Cheers
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 12-17-2025, 03:14 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
The manifold to head gaskets are a common place for vacuum leaks. Check the torque on the hold down bolts.
1986 Targa Guards Red
2021 MT09 SP
Old 12-17-2025, 04:09 AM
Behind the throttle body there is a cluster of vacuum lines that degrade over time. The biggest one that you have to watch out for is the brass pipe that comes out of the throttle body boot going towards the cruise control unit. It generally fails at the reducing coupler.
Old 12-17-2025, 10:16 AM
scarceller's Avatar
Already mentioned, likely the idle switch out of adjustment. Or base idle speed not properly set.
A properly working idle switch should behave as follows:
- Engine fully warm
- Should idle at 800RPM for 84-85 cars and 880RPM for 86-89
- With engine idling properly at correct speed
- If you unplug the Idle Switch, 2 pin connector on RHS of throttle body the idle speed will and must change, it usually goes up above 1000RPM the moment you unplug the switch.
So, if you are at idle and unplug the switch and nothing changes it usually means the switch is not closed and needs proper adjustment OR the switch is bad.
You can easily test the switch with a ohm meter.
To set base idle speed correctly you can email me I'd be happy to send you my own easy procedure or use the Bentley shop manual.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 12-17-2025, 01:25 PM
scarceller's Avatar
Also a bad/failing idle control valve can also cause issues.
Here's another check I have come up with that helps sanity check idle control behavior. Follow these test steps.
- Engine dead cold, must be dead cold!
- Do not touch the gas pedal during any of this testing
- Turn key and start engine, observer behavior at startup. Does it start right up and idle at 1100RPMs? Does it hunt up/down for idle speed? it should not.
- It should start up and instantly idle at 1100-1200RPM at initial cold start
- over the next 3 minutes let it idle while watching idle speed
- the idle speed must come down without you doing anything, do not touch gas pedal just observe.
- After few minutes it should settle down to the target WARM idle speed of 880RPMs
If everything works as outlined above it means the idle switch is closed, the idle control valve works and the mixture is not far off baseline.
Sal
1964 356SC (SOLD)
Old 12-17-2025, 01:33 PM
