bad 2.7 RS.....
Hi all
I finally found my 2.7 RS MFI
This is the baddest Porsche experience i had : some explications :
The engine is impossible to use : no smoothness and power under 3000rpm ,this is because of the lack of care( i mean he didn't take care about it) of the seller.
It runs hard but not regularly from 4000 to 7000 (much too rich , the rear bumper is black and dirty....)
Idle is correct,
here are a few questions : is the injection pump reliable ? does it runs well with modern fuels ?
I feel there's no big problem on that engine but i need your opinion
a good start would be to replace spark plugs, fuel filters, control firing point,
valve seats, pistons/cylinders are new (8000kms), heads have been machined, by the way it doesn't run good
any ideas ?
i'm sure Porsche designed that engine to run well from 1500 to 7000 (because of the MFI)
may you confirm ?
best regards
Philippe
Old 07-16-2003, 03:46 PM
Buy them, sell them
Adam's Avatar
The only 2.7 MFI (RS) engine I've ever sampled was smooth, yet urgent and pulled like crazy to it's rev-limiter. It made good power all through the rev range.
There should be no burping or stuttering and it should rev like crazy.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 07-16-2003, 04:01 PM
Send a message via AIM to 82SC
sounds like your car just needs a good long day(s) in the hands of a competant mechanic
Old 07-16-2003, 04:31 PM
beepbeep's Avatar
MFI space-cam might be worn-down and needs to be resurfaced.
Thank you for your time,
Old 07-16-2003, 04:50 PM
