GeorgeM's Avatar
Brake Cooling Hose Routing
Haven't seen a thread on preferred routing for brake cooling hose in a while.
There was one a while back on options for avoiding the tire rub, etc., but no follow-up on experiences.
The Smart Racing kit seems the cheapest, but $150 still seems like a lot.
Anyone using that kit or another that does a good job of preserving hose. I finally got some of the good stuff and I want to keep it for a while.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 07-17-2003, 11:51 AM
Bill Verburg's Avatar
The SR tubes are a good compromise, but why not DIY just get some 2.5 or 3" DWV tube. The whole trick is to keep the tube low for tire clearance at full lock but no lower than the A arm(anything hanging under the A arm will get ripped off quickly. Hence the split tube that wraps around the A arm. With your brakes you don't even need the full 3" tubes
Bill Verburg
Old 07-17-2003, 02:11 PM
