Curious, what's the difference between the 930 brake pads and the 964 brake pads?
Are they the same in dimensions/thickness?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Porsche Parts Centre just confirmed they are the same pads.
They are the same size pads and are interchangeble but 964s have brake warning sensors.
930f/r, 964 f/r, 993r are the same pad except for sensor wire This is a 993 rear pad w/ sensor wire and a 993 front pad * neither the sensor wire nor the anti squeel spiders are necessary for correct operation
Thanks Bill.
I have a pre-89 911 M491, with the 930 Turbo brakes. Did these use the sesnor wire? I don't think I have a dash LED for this brake sensor. I doubt it was a feature in the pre-89 911's. ONly in the 964's & 993's, right?
I have an '87 M491, and it does have wear sensors on the stock brakes. I installed new sensors when I change pads, ordered from our host.
1965 912 1987 TL Cabriolet |
I thought front and rear pads on 930 brakes were the exact same. According to your picture Bill those 993's look different (F/R)
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
930s use the same pad front and rear. Bill was showing you the pads from a 993. The 930 uses a pad sized like the rear pad on a 993. Ignore the other pad in the picture.
Porsche started installing the brake wear warning lights and wiring on the 1984 cars. The brake warning light on the dash in these cars is divided into two lights, one of which is for the wear indicators. This info is in the cars' owner's manual, for those that want to learn more. JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
