I seem to have a slight oil leak in the area where the oil tank and S hose meet. I've tightened the clamp to no avail. I'm wondering, if I drain the oil from the tank and sump, will there be any oil left in the S hose? I'm thinking about inspecting it and maybe replacing both the hose and clamp. I just don't want to be surprised when I pull it off.
Senior Member
Yes, there will.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Thanks for the heads up, Superman!
Irrationally exuberant
The S hose sits right near the hot exhaust and tends to need replacement sooner than other hoses. I'd change it.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks Chris. I did buy one along with the associated clamps with the intent to replace just in case.
Air Medal or two
oil leak
had the same problem , turned out to be a loose fitting at the tank.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
When you remove the S hose, make sure that the surface on the oil cooler is smooth where the hose seals. A small score can lead the oil right out and onto the heat exchanger.
If you find a score or two, polish them out with the finest grit wet/dry sandpaper that you can find.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Thanks for your responses. Everyone's so helpful on this BBS. I guess that's why I'm an addict.
