'79 911 turbo
New owner and have a couple questions. Compared to a "non-turbo" engine, what regular service items are distinct to the turbo?
I checked the oil level with the dip stick (in the filler nozzle) and it barely registers (when warm & not running), but the pressure gauge reads OK as well as the oil level gauge??? I'll have more questions! Thanks for your help! Rich |
1. There are no turbo-specific regular service items.
2. Your manual states that you should have your engine running when checking oil-level, so why are you checking it with engine off?
Thank you for your time, |
Because I don't have a manual..............
Well now you know...all 911 engines prior to 996C2 and Boxter are dry-sumped and oil-level should be checked with engine running. Overfilling oil beacuse of bad level-checking usually leads to excessive smoke and in worst case, blown seals. Search on "overfilled oil" and you will find out that there are many people who did same mistake. Welcome to Pelican by the way...
Tell us about your car. Any mods? Pictures?
01 996TT 2003 M5 1979 930 (sold) BMW 1200 GS Adv&BMW 100/7 F350 Diesel |
I checked the dip stick level when warm and running, it was dry. I added 3 qts, stopping between each to check level. Now it is slightly above MIN, but the oil level gauge dropped to the top margin of the red zone at the bottom of the gauge, but it is not in the red zone. I'm a little confused, I would think that as you add oil the indicator would go UP not down.
Rich |
hahahaha...I love it when people are so WELCOMING of new members....
remember there are no stupid questions...and 1456 posts ago you were just like him.... welcome to the board... You'll find the members alot more accomodating if you do a search of a topic before posting...I am guilty of not searching too...but especially if you think it is a basic question... like jbryant says...post some pics...details details MJ |
Sorry if i sounded rude, i just believed everybody knew to check the level with engine on.
About oil-level, i say don't trust the indicator, trust the stick. Also, my expirience is that 930 usually runs best when there is just enough oil, with other words, just a bit over "MIN" line... I believe your indicator is a bit rusty (not oiled enough?) so it's not indicating right.
Buy them, sell them
Welcome to the board!
Show us your 930! Quote:
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
Here is a link to some pics, etc. http://mysite.verizon.net/rkh3/porsche
Another question- Would low (3qts) cause "stumbling". I may be sorry to say, I picked up the car last Friday night and it ran fine, except "popping" through the exhaust on decelleration, thought that odd but maybe normal. I drove it a couple hundred miles over the week end-all fine but still "popped". Filled the gas tank late yesterday (another possible cause i.e. bad gas?) and drove it 50 more miles-fine. Today if you hold a speed it stumbles though it accelerates fine. By the way it is fuel injected. There is a slight "tap" coming from the engine, only when warm Excuse my ignorance, but I have been into muscle cars for years, it is probably obvious, but this is my first Porsche. Thanks |
My mechanic says the same thing also. He tells me to fill it with just 10 quarts for an oil change.
I'm sure you noticed immedeatly, this is a conversion. It was born a 911SC.
That's the car that has been on eBay several times in the last year. It looks nice.
80 930 67 Triumph TR4a irs 72 DeTomaso Pantera 75 911 3.3 Turbo Cab*SOLD 5-11-04 73 911T Went Up in a Blaze Glory, 76 Early Ford Bronco |
When the engine gets hot enough at the right RPMs you can see from the cabin guage that this set up will occasionally surge to the top level. The low setting gives you enough saftey margin so oil won't come puking out of your tank breather and really give you a scare something is wrong. With almost 15 quarts in the system you have little to fear about the min setting not being enough oil. |
Buy them, sell them
Your URL doesn't work for me.
1979 911 3.3L turbo cabriolet K27 turbo w/sc cams, matching intercooler Insanity-doing the same thing over and over and expecting different results |
Administrator
Don't trust the gauge in the dash. Trust the dipstick, and make sure the car is warmed up (meaning: 15 minutes or so of driving) before you trust the level on the dipstick. It should be idling on a level surface.
I can't imagine why being 3 quarts low on oil would cause any problems at all, unless you were winding it out like you were on a race track. You've found a great resource for the car in this board. As MJ said, there are no stupid questions.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Any insight into the "popping" through the exhaust on decel?
Buy them, sell them
Possibly an exhaust leak?
