Dave Ploss's Avatar
Plug Change-Can't get wires to slip on plugs HELP!
Plug changes are supposed to be easy. No problem getting the plugs out and the new ones in. I can't get the plug wire to snap on to the plug. It feels like it is hitting something and won't go all the way on.
any suggestions or help?
Thanks.
Dave
Dave Ploss
'87 911 Carrera Coupe - Black
'90 Mercedes 190E
'00 Filippi Lightweight Double
Old 07-27-2003, 11:06 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Dave,
Did the plugs come with the screw on tip removed? I've had this happen before and missed putting the tips on. I'm assuming you have the same wires and bought the right plugs.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 07-27-2003, 11:15 AM
If it's only happening on one plug (the first one and only one you tried so far?) then check for a rubber insert from the plug socket staying behind on the plug. A small flashlight and an inspection mirror is handy for such checking. Jim
Old 07-27-2003, 11:24 AM
Dave Ploss's Avatar
David - the tip is on. They are NGK's.
Jim- No...the rubber isn't there. This happened on the first plug I removed and I'm going one at a time. I started with CYL #1 just to make sure it would be fairly easy to get at. I took the plug out again and the wire goes on with no problem when it is in my hand.
It feels like it is hitting something on the wall and won't go on.
Dave
Dave Ploss
'90 Mercedes 190E
Old 07-27-2003, 11:30 AM
JOT MON ABBR OTH
Dave,
You might be going in at a bad angle. Try a little different approach with the plug wire. One at a time is good, but make sure you don't mix the plug wires. I have done this before and the motor does not run as well ;-)
Old 07-27-2003, 11:42 AM
Dave Ploss's Avatar
I am such an idiot...Jim, you were right. The rubber thing was on the plug. Took it off and the wire went on like silk.
Thanks for the hint...it saved my sanity.
Dave
Dave Ploss
'90 Mercedes 190E
Old 07-27-2003, 11:44 AM
Dave, Just don't ask how I know about the rubber insert Cheers, Jim
Old 07-27-2003, 12:02 PM
JOT MON ABBR OTH
Jim,
You're one of my heros!! I completely forgot about that happening!
Dave,
Re-bond the rubber grommet to your metal socket. I used a silicon based permanent gasket.
Old 07-27-2003, 12:23 PM
