Sealant on tops of shock towers
My car still has the sealant on top of the shock towers. On one side it is starting to crack. Should I remove it from both sides. Any suggestions what would be the best way without hurting the car/paint. Should I just reseal it and what should I use? I have both the Wurth SKS in Grey and the Wurth under body seal in Black but they seem to thin to keep in place until it hardens. The stuff Porshe used almost looks like a paste that when dry turned to a hard rubber. Thank you.....
Old 07-24-2003, 10:28 AM
Chuck Moreland's Avatar
Use a heat gun and scraper to take most of it off. Carefull when you get down to the paint.
Then use castrol purple and scrub brush to get the rest. Or try orange hand cleaner, good stuff.
To replace a bit neater than the factory did, get some rope type body sealant. You can get this at auto paint specialty shops.
Lay the rope down between the camber plate and the tower, work it down in to seal.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-24-2003, 10:32 AM
Early_S_Man's Avatar
Porsche Crest
I am assuming it is the same type of tar-based sealant used in the early 70's ... so any tar removal product, such as Varsol or 3M's Paint Cleaner, should work just fine. All of the tar removal compounds I have used are low-volatility, non-harmful to paint, and very easy to use.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-24-2003, 01:07 PM
I used a blunt screwdriver and "tapped" it off whacked by a hammer....worked better when it was cold in the garage rather than warm..when I finally finished doing this.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-26-2003, 07:04 PM
Pic with the tar-like sealant removed.
I've considered "re-tarring" in the name of originality, but haven't had the heart to do it.
Old 07-26-2003, 11:44 PM
Stressed Member
Scott Clarke's Avatar
Anybody know why that tar is there? Is this somewhere that rust might fortm?
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 07-27-2003, 07:07 PM
I don't think it is for rust prevention, since the chassis is painted.
I think it is probably to prevent the possibility of water from coming into the trunk from that area.
Old 07-27-2003, 07:17 PM
Wow, darn nice trunk, SoCal. How long did it take you to do that, and what did you use?
Old 07-28-2003, 08:55 AM
KTL KTL is offline
Schleprock
KTL's Avatar
You think the trunk is nice?
Ask him to show you a shot of the underneath of the car.
Downright shocking!
Kevin L
'86 Carrera "Larry"
Old 07-28-2003, 09:08 AM
304065's Avatar
sound deadening
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-28-2003, 09:24 AM
