Need to vent, my gas tank
'73 project car. I need to vent the gas tank.
The factory vapor recovery system has been sacrificed on the alter of weight reduction. I need a vent that will not allow fuel to escape when sloshing about or even in a rollover. I have a hose fitting on the tank and another at the filler neck, either could be used. Suggestions?
Chuck Moreland - elephantracing.com - vonnen.com |
PRO Motorsports
You'll have to connect the two, or fill-ups could get interesting! Then you need to T off of them and run it to an expansion tank that vents to the outside of the car.
Put a one-way check valve on the hose coming from the T that goes to the expansion tank that will allow air to be drawn into the fuel tank, but won't let fuel spill out. I kept the factory set-up on my car, and even bought a brand new charcoal cannister from the Dealer. It doesn't weigh much, is environmentally consciuos, and avoids venting issues, spillage issues, and fuel vapor odor issues. O.K., so I'm a bit of a tree-hugger.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Chuck: I had to sacrifice my vapor recovery tank when I installed my auxillary a/c condenser/fan set-up. I'm in the midst of the installation. Here's what I plan to use to replace the vapor recovery tank:
It's smaller than the factory tank, but should do the job. What the picture doesn't show is the fitting hole on the end. I'll use two of the three holes, and plug the other. I've been told that the vacuum hose must be lower than the hose from the fuel tank. So, I'll mount the vapor recovery tank vertically (or nearly so), and vacuum from the fitting on the end while filling from one of the fittings on the side. Scott
1984 Targa Last edited by scottb; 07-29-2003 at 06:04 AM.. |
Where can I get a check valve?
Certified Pre-Owned
McMaster has some mini polypro spring loaded ball check valves.
search "check valves" and then click "miniature check valves", page 2. -BG
'84 Carrera Coupe |
Certified Pre-Owned
Which also makes me wonder, how do they vent a fuel cell? Or don't they...
'84 Carrera Coupe |
SCWDP- Shock and Awe Dept
Chuck, do you have any way to hook an evap tank up to vacuum? That would eliminate the need for any check valves and you wouldn’t need to worry about venting to the ground.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
I'm looking for some feedback here.
This is the current plan: The check valve allows air into the tank, but nothing to escape. This should be safe in a rollover. It appears the fuel cap can prevent overpressure in the tank. The seal is spring loaded. I have seen products that flow in both directions, but close off due to gravity in a rollover. However I fear those products may not close off if the car rolls on its side. Tyson, You suggest an expansion tank. I don't understand how that would work or help. If it is vented, how does that prevent fuel spillage? If it has a check valve, why do I need a tank?
PRO Motorsports
The expansion tank isn't really necessary if you use the check valve, but it does add that extra measure of protection. The tank gives the fuel a place settle, and the vent is at the top of the tank, so it's essentially just a back-up.
The other type of expansion tank, (the factory set-up had both) is placed in the highest place possible,(under the dash) and is there to allow the fuel vapor to accumulate and condense back into fuel droplets and run back into the tank. This essentially keeps you from getting really bad fuel mileage while your car just sits there! It helps keep the fuel in the tank. You don't really need this one either.
So you think my drawing will work?
What about overpressure in the tank, will the spring cap relieve this safely?
PRO Motorsports
Yes, and also if you use a stock check valve, it allows minor pressure to freely escape, but if it gets a large volume quickly, or fuel pushing against it, it shuts off.
Reviving this thread...
Chuck did you ever implement this? If so, did you follow your diagram above and what parts did you use? And... how well does it work? Thx! I'm asking b/c I discovered that my left fender exp. tank is trashed and it costs $70 (!)
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
On all cars today, a check valve is built into the gas cap. As part of the smog check, it is removed and pressure tested to hold pressure but allow air inside to prevent a vacuum from forming inside the tank.
Joe |
Porsche-pa
For those who may still have the original stock canister; 1. Have you ever serviced the thing? 2. How much charcoal is it supposed to hold? (To fill it up would weigh a ton)
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious), Also rans... '02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7, Donny |
