Adman's Avatar
Send a message via AIM to Adman
Dansk single in single out sport muffler Part Number?
Guys...any of you happen to know the part number for the Dansk single in single out aluminized sport muffler for an '87 carrera? Matthew
Old 07-19-2003, 02:14 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Here you go these are the 70 mm and 84 mm Tips and a
84 mmTwin tip
part # 10 1010 157
Muffler Sport Aluminized Steel with Black Finish 70 mm Stainless Tail Pipe
part # 10 1010 154 Muffler Sport Polished Stainless Steel
84 mm Tail Pipe
Heres nice pipe this one, the tips are loose and you weld them on were you want
part # 10 1010 156 Muffler Polished Stainless Steel 84 mm Dual Tail Pipes-Loose, to be welded at desired position.
We have them here at Pelicanparts. Steve
Old 07-19-2003, 03:35 PM
Adman's Avatar
Thanks Steve. Any idea when the aluminized sport will be back in stock?
Matthew
Old 07-19-2003, 04:52 PM
Dansk should also offer a loose tip version for the 84mm tip. They really don't quite fit right through to valence opening.
Old 07-20-2003, 12:39 AM
Mikkel
Guest
Posts: n/a
Dansks own number:
Single in single out 84mm: 92.502SL
Loose tail pipe: 92.250S
Old 07-20-2003, 06:50 AM
Adman's Avatar
Originally posted by Mikkel
Dansks own number:
Mikkel do have the number for the aluminized sport?
Matthew
Old 07-20-2003, 08:31 AM
Mikkel
Guest
Posts: n/a
The number above is for a stainless steel "sports" muffler. I found it in a Dansk catalogue that I have. The non stainless steel OEM has a 60mm tail pipe. I think it's called 92.201 However it seems that it's also available in stainless, 92.201S
Old 07-20-2003, 09:47 AM
Adman's Avatar
Mikkel...Dansk also has the,"Sport" in the aluminized version and it comes with a 70mm tip. I dont think they were available until early this year. It may not be in your catalog.
The aluminzed sport that I am looking for is out of stock at Pelican and every where else that I have checked. Looks like I will end up buying the S/S Sport!
Appreciate your help.
Matthew
Old 07-20-2003, 11:48 AM
Danskman's Avatar
Matthew... just saw this thread today. The Dansk aluminized steel sport muffler (painted in crinkle black, with a polished stainless steel 70mm tailpipe) is a 92.501 (Dansk p/n). You're right, for some reason everyone has run out of stock on them. Pelican should be able to get you one after August 11. That's when stock should once again be available.
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 07-29-2003, 03:56 PM
Adman's Avatar
Mike...we had spoken to each other on the phone...way back then! Thanks for the post.
Old 07-29-2003, 04:01 PM
