North Coast Cab's Avatar
DAS Sport Roll Bar Install
I lucked into a deal on a DAS Sport roll bar for my cab. I layed it in place and it looks like the rear seats need to be removed for access to the rear mounting bolts.
Does anyone have the factory instructions?
JG
1985.5 944 GTS
Old 08-25-2003, 05:17 PM
BlkBird's Avatar
Just the upright sections of the rear seats. Undo the single bolt on the outside of each flip down section, and slide off the center support pins. Your DAS roll bar should fit right in place and you can use the stock bolts to mount it.
The front mounts go where your seatbelt attachments are - but you have probably figured that one out.
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 08-25-2003, 05:49 PM
BlkBird is right, I just installed mine last week. Send me a PM with your fax # and I will send you the install instructions if you still need them.
Old 08-26-2003, 02:12 PM
