Bones's Avatar
Lazy speedo
The car is a '78SC ...today whilst driving normally my speedo started to read roughly a third of the cars
estimated speed judged by looking at the rev counter . ie at x revs in top it used to read 90mph , now it reads 30mph but otherwise operates normally . Does anyone know if this is the gauge or a cable problem .
Old 07-31-2003, 05:47 AM
Bones's Avatar
bump
Old 07-31-2003, 08:03 AM
maybe start by checking the performance of the tranny sender
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-31-2003, 08:15 AM
Bones's Avatar
bump
Old 07-31-2003, 02:38 PM
Pat S's Avatar
I had that happen on a 66 Dodge many years ago, ended up being a broken cable. I had an additional symptom (aside from slow speed reading) of a bouncing needle when accelerating though. This assumes of course you have a mechanical gauge and not electrical.
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 07-31-2003, 02:45 PM
makaio's Avatar
Bones, did you ever solve your problem?
I'm experiencing a lazy speedo on my 86 right now. When taking off from a stop it doesn't start reading untill about 35-40mph, then picks up right around where it should be. Anybody else had this kind of problem?
Old 08-24-2003, 04:32 PM
Cool
Nope..
maybe some electrons get lost at low speeds inside the case. Warren might suggest a scope.
I would probably borrow a known good speedo for info.
... Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-24-2003, 11:19 PM
Bones's Avatar
No Matt I haven't got to the bottom of it, I'm thinking it's the sender as it's electronic. I would have already replaced it but it seems like a bit of an involved job. Has anyone else replaced the sender and if so how difficult is it?
Old 08-25-2003, 02:46 AM
makaio's Avatar
Thanks Ronnie. I'll pull it out and take it to Palo Alto Speedo when things slow down around Winter.
Bones, if you change the sender, let me know what a PITA it is or isn't.
Old 08-25-2003, 05:16 PM
Cool
the sender is easy on a 915. a spring clip on the tranny and a plug in the cabin tunnel. and there is a sender test in my books somewhere. something about jacking up the rear wheels and turning them about 6 times and watching a volt meter jump a fixed number of times.
and the good news is that the car is now, finally, prepped for carbs.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-25-2003, 09:42 PM
makaio's Avatar
Your're going to make the switch? Did you change the cams and pistons?
Old 08-26-2003, 09:32 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Not to freak you out, but your symptoms sound strangely familiar.
There are a series of magnets in the tranny that send a pulse to the speedo sensor at each passing. If one of these were to fall out of its housing...guess where ends up....flopping around somewhere in your tranny.
See:
Don"t Let This Happen To You! (long
Edit: Just noticed your speeds dropped more than half.....doubt more than half the magnets fell out. Just consider this an FYI then
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 08-26-2003, 09:59 AM
Cool
Yep..
been prepping the car for this.
it already has the RS 8.5 pistons.. the cams are here already.. had them brand new for over a year. so my next act is to start getting the parts together for this, thus PMO, etc. now.
I want a fun car again.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-26-2003, 10:35 AM
CJ CJ is offline
CJ's Avatar
I had the same problem, first intermttent loss of reading and eventually no reading at all. Replaced the sensor and now I get a doubled reading. The sensor is easy to replace and I have heard that the retaining clip should be either replaced or carefully positioned or you may get a faulty reading. I will be adjusting my new sensor soon to see if I can get a correct reading.
Chris Johnson
87' 3.4 Carrera
73' 911t restoration project
Old 08-26-2003, 12:44 PM
makaio's Avatar
(Bones, I really didn't mean to hi-jack your thread)
Charlie, I read that thread when it was first posted, definatley spooky, and I hope that's not what has happened to me.
Old 08-26-2003, 01:15 PM
Bones's Avatar
Don't worry this is all interesting stuff just like most threads here. lol
Old 08-26-2003, 01:17 PM
