VDO Speedo: Repair or Replace
Hello all:
I've got an '87 Euro Targa with the kilometer speedo. The odometer portion packed up a few years back so I had it overhauled (the gear train was totally destroyed). It has now quit again.
I'd like to keep the car as originally fitted but would like opinions as to whether a series of VDO overhauls is the way to go or if a reasonably authentic and reliable substitute might be a better option.
If the latter, what would it be and where would I get it? Does it just attach to the existing leads?
Regards
D the P
Old 08-02-2003, 11:20 AM
nestorjw's Avatar
Send a message via AIM to nestorjw
Send it to Hollywood Speedo. then you should be ok for quite a while
Jeff
83 SC, Guards Red.
Old 08-02-2003, 01:45 PM
The odometer will continue to go. Generally they go because the trip odometer is reset while the car is in motion.
Don't reset the trip odometer unless you are sitting still, it uses a plastic gear and will continue to break from time to time, but the rest of the speedo should be fine.
Old 08-02-2003, 02:28 PM
http://www.odometergears.com/
There are a lot of threads on this. I found them because I had the same issue. I just installed my new gear and it was pretty easy. Maybe this will work for your '87.
Old 08-02-2003, 06:16 PM
Thanks, that's helpful.
mr.bch, does the speedo dissassemble easily or are there "issues" for the ham-fisted?
Old 08-02-2003, 11:34 PM
Geting the rings off is a little tricky at first. You just pry it off with a couple of screwdrivers. But the ear is right there on the end and held in by 1 'E' clip. Small, but not hard to do. For 29 bucks, try it. I can post some pics of how I took it apart, if you want.
Old 08-03-2003, 09:09 AM
Ray 911s's Avatar
I'd like to see the "how-to" photos of your speedo repair. I need to replace the gear in mine as well. Thanks!
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 08-03-2003, 05:18 PM
