Looking for some kind of front valance
I need to accommodate an oil cooler in the front of the 911 narrowbody. I haven't seen much out there, and was hoping someone can turn me on to a used part or an idea for something I haven't seen. I don't want it to look to radical...I prefer a stealth approach.
Thanks for any and all ideas...
Old 08-02-2003, 02:58 PM
ZAMIRZ's Avatar
I want to get a front valence too and am seriously looking at the Ruf lower piece with fog light and center oil-cooler opening. Unfortunately I haven't been able to find it anywhere at a reasonable price (Weissach wants $1200 for it), any leads?
Here it is on GeorgeM's beautiful green 3.2 carrera:
later,
amir
Amir
'83 911SC
Old 08-02-2003, 03:03 PM
Another Pelicanite wanted the same thing (more room, stock looks), so he bought a second stock valance, did a little creative cutting and welding and ended up with a completely stock looking valance complete with front lip spoiler with enough room for a front cooler.
Just a thought, otherwise the Ruf style is the most inconspicuous. Call MAShaw, they have parts that they don't advertise on their site or in their ads. They may have something for you.
Old 08-02-2003, 03:19 PM
Cool
Hey Steve..
I think this is what you mean.. I have it here.. gotta do some glass and paint.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-02-2003, 04:30 PM
Hey Ron,
Is that your handywork? If so tell me about it. I am thinking of the same sort of cooler mod. What cooler did you use?
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 08-02-2003, 06:48 PM
Formerly bb80sc
Vipergrün's Avatar
Here is a 930S valance on my SC. I love the look and the oil cooler install was cake
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 08-02-2003, 06:51 PM
Originally posted by Blown
Hey Ron,
No Dean.. it belonged to GeorgeM before he moved back to Europe.
Valence Options after Deer Strike
I jumped on it real quick.. it's not even installed yet.. it's a really nice custom low key valence. kinda like you have to know what your looking at style
I'm still waiting for a front shield. mine is already removed .. I did the roof lining, and did the 3M Windo-Weld, 3M08633, like you said on the rear window after install.. so the valence repair and paint may have to wait till next season.. I haven't installed the new cams yet either.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-02-2003, 07:31 PM
Brad,
Is that fiberglass?
And
Thanks Ron
Dean
Old 08-02-2003, 08:00 PM
It'll be legen-waitforit
stealthn's Avatar
Brad,
Are those SC fogs or Carrera's?
Is that from Betterbodies? looks great do you have any side shots?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 08-03-2003, 09:16 AM
Those look like Carrera fog lights. Pretty much all of the valances that are setup for fogs are set up for Carrera fogs.
Old 08-03-2003, 09:24 AM
First off I would like to say, that is one beautiful girl you have there Blown!
As for the front Valance I'm getting one from:
http://www.gt-racing.com/catalog/default.htm
Probable 43D
As for the oil cooler, I have found some nice ones that are very affordable over @
http://www.alamomotorsports.com/pmc/Contents.html?source=google
Old 08-03-2003, 10:29 AM
Hey thanks Frostie.
I kinda wanted to stay away from fiberglass because there are a couple of driveways that might murder the valence. I was also looking at the long Mocal oil cooler because of the dimensions. I also like the idea of going custom like Ron is, because I like to spend a rediculus amount of time on something instead of just going out and buying it. Doh
Dean
Old 08-03-2003, 01:29 PM
Ho Hum 74's Avatar
Amir,
That spoiler you want is not the Ruf one. The Ruf "Yellowbird" bumper replaces your stock one. What you are looking at is the 930 FSR spoiler which runs $349 at Vertex Auto. They have the Ruf kit for $1175 front and rear.
Cheers,
Tristan
Old 08-03-2003, 07:00 PM
One thing to think about - if you ever intend to compete in your car then a fender mounted cooler is a much safer idea. The front bumper is always the first to go. I just pulled a (busted) setrab cooler out of the nose of my RS replica and replaced it with a 3.2 cooler in the right hand front guard for this reason. OTOH - in the nose is fine for a street only car.
Cheers - Ryan
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 08-03-2003, 07:55 PM
GeorgeM's Avatar
Thanks for the kind words Amir.
Here's a closeup of my old custom valence that Ron now has.
I got my Ruf style from Brad at BW Motorsports. My paint guy said it's the best glass work he's seen in a long time. The fit was perfect. I made the grilles out of a used decklid grill that I got on eBay.
Here's a quick description from another thread:
The idea was to make something that an oil cooler would fit behind. I got two used valences, one with fog light holes, one without and cut 'em up to make a custom valence.
I moved the Carrera valence forward to the edge of the bumper and welded on longer ends from the older part. Then cut a hole for the cooler and mounted BSR ducts (from I/O Port) behind the fog light openings.
I also had to piece together a longer rubber lip spoiler from two used ones.
It wasn't a hard job, just took a while since I was making it up as I went along.
This way, I was able to retain as stock a look as possible and have the room for the cooler (just barely enough).
If all you want is brake ducts, just get the used Carrera piece and use the BSR ducts. I put a double duct on the passenger side to get a bit more air to the fender oil cooler. Not much room in there, so you'll have to trim the inboard duct and put the brake hose on the outboard one.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 08-04-2003, 06:38 AM
Formerly bb80sc
Vipergrün's Avatar
Dean, yep, it's fiberglass....and Carrera fogs. I have toyed with the idea of removing the fogs and going with brake cooling ducts. I've got some 3/4 view shots I can post later.
Cheers
-Brad
2015 Cayman GTS
Old 08-04-2003, 06:51 AM
stealthn's Avatar
Brad, sweet, which oil cooler did you go with? Who did you get the spoiler from?
Does anything need to be done to the oil pump considering the extra distance?
Cheers
Bob James
18 Macan GTS
Old 08-04-2003, 07:55 AM
Formerly bb80sc
Vipergrün's Avatar
Bob, the valance is from betterbodiesmotorsport.com. I went with a Setrab (aka Mocal) cooler and mounted it to a bracket, which is bolted to the underside of the actual bumper. AFAIK, nothing additional for the oil pump. The only modification I made was to remove the studs from the valance that the mesh grill attached to for clearance. The mesh and the cooler have become *one* via the way I mounted it.
Cheers
-Brad
2015 Cayman GTS
Old 08-04-2003, 08:06 AM
GeorgeM's Avatar
Mocal 44 row from BAT Inc. in Sarasota.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 08-04-2003, 12:02 PM
Sweet...very very nice!!!
Old 08-04-2003, 01:00 PM
