by-pass pipe problem??????
I have a 911 ,89 model ,3.2 that I put a by-pass pipe on . after
the pipe was installed the car sounds good but doesn't run as good the car seems to be running too rich . could removing the cat. cause the oxygen sensor to not work right ? Does the car need the back preasure and heat of the cat. to function correctly?
The car has 82k on it and is holding 170 to 175 # compression each cylinder , but the plugs were wet. It also seems to be smoking (blue and black) more than it did and has a very rich exhaust smell . Does the car have an egr valve ? do I need an oxygen sensor or to re-install the cat.?
Old 08-07-2003, 08:05 PM
DID YOU REPLACE THE O2 SENSOR BACK INTO THE EXHAUST AND IF SO DID YOU MAKE SURE OF THE CONNECTIONS? IF SO AT THAT MILAGE IT MIGHT BE TIME FOR A NEW O2 SENSOR.
KEITH EPPERLY
87 911 CARRERA CABRIOLET SLANT NOSE WIDE BODY TURBO LOOK
Old 08-07-2003, 08:24 PM
It needs an O2 sensor for the computer to function correctly; a missing or disconnected O2 sensor will make it run too rich. Was there a bung in the cat pipe to reinstall the sensor and/or was the sensor reconnected after the install? A cat pipe will relieve back pressure somewhat (a good thing for your car) and will run cooler than the converter (also a good thing). The black smoke and smell indicates that it is running too rich so you should look into the sensor situation a little further. I put a cat pipe on my 88 and it made a difference for the better. You won't pass a smog test with a cat pipe, tho, if that is an issue.
Argo
88 Targa
Old 08-07-2003, 09:15 PM
by-pass & 02 sensor
my car does have the 02 sensor connected , it was hard to get out of the old cat but I did get it in the new pipe . I will check the connection again and if that doesn't help I will replace the 02 sensor. the car seems to take longer to rev and like I said is blowing black and blue smoke and the new 4 prong platium
plugs were wet . thanks for the help!
Old 08-08-2003, 07:29 AM
