-   -   911, 2.2S AND 2.4T what can I do? (http://forums.pelicanparts.com/porsche-911-technical-forum/122563-911-2-2s-2-4t-what-can-i-do.html)
DIEGO nasti 08-08-2003 11:33 AM
I have two engines 911, one is 2.2S and 2.4T
are there any parts that I can exchange between them
to get more HP?
dtw 08-08-2003 11:42 AM
Put the pistons, cylinders, and cams from the 2.2S into the 2.4T. Make sure the pistons measure out to within specifications though. My experience after looking at many many early pistons is that they have not survived 3 decades of use.
Early_S_Man 08-08-2003 11:59 AM
2.2 "S" heads were the same as 2.4 "S" heads ... much larger ports than the "T" heads, so they need to go on the 2.4 as well, along with the MFI throttle bodies and stacks that matched the "S" port size! If the 2.2 engine is running well with no richness issues, I would recommend using that MFI injection pump as well! Ignition timing would have to be retarded a bit to around 30° - 32° BTDC at 6000 rpm to handle/deal with today's 'premium' gas. <b>The resulting compression on this engine will likely be ABOVE 10.0:1, so fuel quality will ALWAYS BE A CRITCAL ISSUE!</b>
DIEGO nasti 08-08-2003 12:31 PM
thanks Dave and Warren for your interest.
( I´m using weber 40mm)
how much HP would I get from that set up.
jluetjen 08-08-2003 12:55 PM
190 HP +/-
Randy Webb 08-08-2003 01:39 PM
Doesn't the T have an unbalanced crank? I'd address that before hotrodding it.
Tim Walsh 08-08-2003 01:39 PM
The 2.4T crank is counterweighted, the 2.0 and 2.2 T crank is not counterweighted
