911, 2.2S AND 2.4T what can I do?
I have two engines 911, one is 2.2S and 2.4T
are there any parts that I can exchange between them
to get more HP?
Old 08-08-2003, 11:33 AM
dtw dtw is offline
GAFB
Put the pistons, cylinders, and cams from the 2.2S into the 2.4T. Make sure the pistons measure out to within specifications though. My experience after looking at many many early pistons is that they have not survived 3 decades of use.
Several BMWs
Old 08-08-2003, 11:42 AM
Early_S_Man's Avatar
Porsche Crest
2.2 "S" heads were the same as 2.4 "S" heads ... much larger ports than the "T" heads, so they need to go on the 2.4 as well, along with the MFI throttle bodies and stacks that matched the "S" port size! If the 2.2 engine is running well with no richness issues, I would recommend using that MFI injection pump as well! Ignition timing would have to be retarded a bit to around 30° - 32° BTDC at 6000 rpm to handle/deal with today's 'premium' gas. The resulting compression on this engine will likely be ABOVE 10.0:1, so fuel quality will ALWAYS BE A CRITCAL ISSUE!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-08-2003, 11:59 AM
thanks Dave and Warren for your interest.
( I´m using weber 40mm)
how much HP would I get from that set up.
Old 08-08-2003, 12:31 PM
jluetjen's Avatar
190 HP +/-
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 08-08-2003, 12:55 PM
Randy Webb's Avatar
Doesn't the T have an unbalanced crank? I'd address that before hotrodding it.
Old 08-08-2003, 01:39 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The 2.4T crank is counterweighted, the 2.0 and 2.2 T crank is not counterweighted
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
