Metal Guru
Front Bushing Dimension
Could someone measure the thickness and diameter of the flange on a poly front bushing and post it here for me? I'm going to make my own bushings and that's the only dimension that I don't have. Thanks.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
thickness of the flange 8mm
outside diameter of the flange 61mm HTH, Jeroen
WWW.9GEAR.NL |
