UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
Question What is this connector for (pic)?
Ok, when I pulled my engine, this connector was not connected. What is it?
Matt
'82 911SC Targa!
Old 08-10-2003, 02:21 PM
bumpity, bump, bump! Cmon, somebody has to know what this is?
Matt
'82 911SC Targa!
Old 08-10-2003, 05:37 PM
That connection sends a signal from a switch that shows whether there is air moving through the CIS system. It measured where the air plate is, and is an indication that the engine is running. The signal goes to the fuel pump control system. When the engine is not "running", the fuel pump runs on the "starting" circuit of the controller -- it runs when the starter is engaged, otherwise it is off. After the engine is running, the controller switches to the "run" circuit for continuous operation.
Old 08-10-2003, 06:11 PM
How could my engine be running fine with this disconnected then?
Matt
'82 911SC Targa!
Old 08-10-2003, 06:36 PM
With that connector unplugged, the fuel pump runs the entire time the ignition switch is in the 'on' position. The engine will run fine.
With that connector plugged in, the fuel pump only runs when the engine is running. It helps prevent this from happening :
Old 08-10-2003, 07:43 PM
Krikey!
Audi B7 S4
Old 08-10-2003, 07:52 PM
sheesh! Dont do that!
Matt
'82 911SC Targa!
Old 08-10-2003, 08:02 PM
ruf-porsche's Avatar
Perhaps that is why my fuel pump run whenever I have the key in the run poistion without starting the engine.
Wouldn't this help a bad fuel accumulator or check valve at the pump by having the system pressure before startup?
I think I'm going to follow my own advice if it working fine don't f**k with it.
Old 08-10-2003, 08:06 PM
Yup. These get unplugged so you don't have to actually fix what is wrong with your car.
-Rob
1980sc
Old 08-10-2003, 08:10 PM
What's the symptoms of the accumulator or check valve being broken? I'm assuming that since I pulgged it back in I should expect something not to work.
Matt
'82 911SC Targa!
Old 08-10-2003, 08:23 PM
Hard starting symptoms.
Old 08-10-2003, 08:32 PM
