Kevin Stewart's Avatar
3.6 she's alive i say, WOW, but
I finnaly got the 3.6 conversion up and running after many months of B.S. I will say as the front of the car lifts up and it takes off like a jet, its fast, the wife went with and her reply was holy *****, this car is fast, it has a rattle in the engine compartment i hope its only somthing loose, every thing seems to be in order but this idle problem, seems to be the same as Moses is having, when you start it, it stalls if you dont hit the gas, then idles up and down etc but if you tap the peddle lightly it settles down, putting the clutch in to stop yep it stalls, any IDEAS,
Jack O, yes your right i have no tail pipes yet and it is LOUD, the B&B headers and muffler are cool but loud, im gonna try the smaller tail pipes like you did, i think its louder then my race car,
i will say that everyone keeps trying to describe it but, im telling you its amazing, but i have stripped the car down alot, i will wake up the local vettes with it, of course with a grin ear to ear,
Widebody, i cant get you rs tube to stay in place it hit the motor mount bracket any ideas,
the 3.0 just doesnt compare to this, it kinda reminds me of a hemi gtx i had when i was a kid, ****s and gets
Old 08-09-2003, 12:12 PM
tholyoak's Avatar
Kevin
I bet your throttle linkage is hanging up and not closing the idle switch contact when you let off the throttle.
Todd
1989 911 Targa
Old 08-09-2003, 01:22 PM
Todd you think that would cause the slight hesitation when traking off, Kevin
by the way thanks for your help
Old 08-09-2003, 01:39 PM
PRO Motorsports
Tyson Schmidt's Avatar
Todd's right.
Also, it's very common for the idle mixture to be too rich. You can lean it out by backing out the 3mm adjuster on the airflow meter. It's not a very sensitive adjustment , and may take 2 or 3 full turns. This is for the flapper style only, not the mass air system of the later 993 3.6's.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-09-2003, 01:47 PM
Tyson that may explain why it has the 3.0 rich smell, ill look at it tomorow, i may have the throttle cable adjusted to tight, thanks for your help, Kevin
Old 08-09-2003, 01:51 PM
tholyoak's Avatar
Kevin
On the first 3.6 conversion I did, we used the cruise cable setup provided with Steve Timmin's kit. We found the exact symptoms you had (since we also had the check engine light hooked up it would also come on) We traced it to the linkage not closing due to the cable setup not being ideal. We got around it by adding an additional return spring to the throttle.
On my 3.6 I used the standard bell crank setup on the motor and trans and lengthend the actuating rods as necessary.
Todd
1989 911 Targa
Old 08-09-2003, 01:53 PM
ok Todd i lost you, I gotta roll, but please post more on this and ill check it later when I get back, Kevin
Old 08-09-2003, 01:57 PM
Bill Verburg's Avatar
2 in one day! congratulatons!!
Bill Verburg
Old 08-09-2003, 02:55 PM
As far as exhaust goes, I can recommend B&B headers with the Timmins muffler set up with twin resonators. The sound is crisp, deep but in no way overbearing. It even quieted down a little further after a couple of hundred miles like a Borla system does.
Lew
Lew Ledyard
'88 911 Cab 3.6
'71 911T 3.0
Kirkham 427
Old 08-09-2003, 03:27 PM
tholyoak's Avatar
Kevin
A standard bell crank on the motor (this one was from a 3.2) was used and mounted in place of the factory cruise control unit on the 3.6 as shown below. I left it mounted on the stilts of the cruise control to allow the factory fuel line to still run underneath
The actuatting rod on the right (the black one from the bell crank on the tranny) was lenthened with a short piece of M5 threaded rod, an additional piece of M5 threaded rod was used to make the rod to run to the throttle.
Stock rod ends were used to connect the bell crank to the throttle
At the throttle body end the ball from the cruise control was adapted onto the throttle body lever
Hope this clarifies what I was refering to.
Todd
1989 911 Targa
Old 08-09-2003, 04:04 PM
Thanks, Bill
Todd tomorrow i plan to just sit down and make sure the throttle cable isnt over tight etc, thanks for your input, Kevin
Old 08-09-2003, 11:48 PM
Know that I have woke up, i have Timmins cable type , thanks for the pictures Todd, I understand the bell crank type now, Kevin
Old 08-10-2003, 08:23 AM
Todd and Tyson you guys are right the cable was to tight i plan to also put a spring on it to help reach the idle switch, it still hsitates when you want to take off, so i plan to take it and get the oxygen gas mixture set, any ideas what it should be with a cone filter, Thanks guys, Kevin
Old 08-10-2003, 07:43 PM
