H.G.P.'s Avatar
What are the normal and maximum operating temperatures for early 911s? Thank you.
I would like to know the answer to two questions, restricted to early 911s only:
1. The normal operating temperature for an early 911 (mine is a 1969 911 E coupe) ? and.....
2. the maximum operating temperature for the same year (or comparable year) ?
Thank you
(I have a "dial-in" thermostat, apparently)
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 08-14-2003, 12:54 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I know that my thermostat opens at 185 F. I belive yours would open at the same time.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 08-14-2003, 12:59 PM
H.G.P.'s Avatar
Mine has the "dial in center screw" on the top. I believe Tyson mentioned this thermostat was in some racers at a shop. So I'm not sure. The central "dial-in screw" is currently set approximately half way in?
and I am uncertain as to the temperatures I am to look for as mentioned in the above first post.
1969 911 E Coupe
Old 08-14-2003, 01:13 PM
HarryD's Avatar
Henry,
On normal days my 1973.5 CIS engine runs between 180 and 210. At AutoX, it will spike a bit above 210 but never as high as 250.
Hope this helps.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-14-2003, 02:11 PM
Administrator
Jack Olsen's Avatar
180-220 would be the normal range. 230 and above is getting hot. 250 is shut-down-and-cool-off time.
Old 08-14-2003, 02:14 PM
H.G.P.'s Avatar
OK, that's currently my normal range.
Thank you.
1969 911 E Coupe
Old 08-14-2003, 08:48 PM
