1yearonLy's Avatar
Unhappy Glued Gasket Nightmare
Unsure of my '68's cam chain tensioner history I dug in there to find gaurds already in place. Excellent.
The problem is that the last time someone was in there they glued on the cam chain cover gasket and it has adhered to that face. It only comes of in minute little pieces leaving the glue residue. A nightmare for sure.
Any ideas on how to remove that gasket? is there some gasket remover that will break it down to where it's possible to get it all off in under a day?
I am beside myself on this...
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 07-30-2003, 08:29 AM
buck knife. normal problem.
206 637 4071
Old 07-30-2003, 08:31 AM
1yearonLy's Avatar
I thought about this but was afraid it would score up (uneven) the surface and beg for leaks. No??
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 07-30-2003, 08:39 AM
Senior Member
Superman's Avatar
Yes, if you gouge up the surface, it will be difficult to get it to seal. Still, your best bet is to carefully scrape it with a sharp knife.
Mocha 1978 911SC. "Coco"
Old 07-30-2003, 08:43 AM
1yearonLy's Avatar
Is there a solvent or anything that will loosen it up? It's like hardened candy now.
One more question... Do I need to drain the oil to replace this cover and gasket?? I wouldn't think so but I figured I should ask.
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 07-30-2003, 08:46 AM
n8marx's Avatar
Razor blades always worked on my Chevies. It seems everyone uses a quart of blue RTV when they assemble a 350. And they still leak.
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 07-30-2003, 08:47 AM
Friend of Warren
I use a steel putty knife that I sharpened the edge on. Less chance of digging into the aluminum that way.
Kurt V
1yearonLy's Avatar
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 07-30-2003, 08:48 AM
Friend of Warren
No
Kurt V
Old 07-30-2003, 08:56 AM
AFJuvat's Avatar
Do not have to drain the oil - but keep a drip pan handy for any drips.
WD-40 or carb cleaner tends to loosen old glued on gaskets - with a trusty old razor blade.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-30-2003, 08:58 AM
1yearonLy's Avatar
You guys are awesome, thanks for your help. My plan of attack:
-Get all the way back in there
-WD40 the gasket and let marinate
-Carefully razor blade that old one off
-Back myself out with a new cover gasket, muffler gaskets and straps.
-Cross thy fingers.
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 07-30-2003, 09:13 AM
TMH TMH is offline
TMH's Avatar
If you want to be really careful at first you can try a plastic putty knife. Might not be strong enough, but with solvents it might be. Then I have always used a pneumatic die grinder tool with a wire brush attachment to get the residues off.
Good luck,
Tom
Old 07-30-2003, 09:20 AM
scottb's Avatar
Would it be appropriate to use a strong solvent like brake or carb cleaner?
1984 Targa
Old 07-30-2003, 09:43 AM
Zeke's Avatar
And I use a carpenter's wood chisel mostly because I'm a carpenter. Works the same as the stiff putty knife, which is very well.
Also, I use lacquer thinner or MEK on anything that it will disolve which doesn't include RTV. Better to do it passively than to chew up the surface. I like the idea of a plastic one and I see those in the wallpaper section at the Home Defect. Gonna get a couple.
Old 07-30-2003, 10:19 AM
i also have a nicely sharpened narrow wood chisel that works really well around all the studs.
206 637 4071
Old 07-30-2003, 11:42 AM
Original Owner
tsuter's Avatar
I use a regular old plastic dinner knife like you get on the airlines these days. I just sharpen it to a razor edge on the grinder first. It ain't gonna nick your surface! Guarenteed!
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 07-30-2003, 01:01 PM
Alan Cottrill's Avatar
goof off works miracles
big AL
'77 911
Old 07-30-2003, 01:23 PM
on-ramp's Avatar
"WD40 the gasket and let marinate "
LOL, I like your choice of words, as if you're preparing a large T-bone steak for the grill
good luck
Old 07-30-2003, 01:39 PM
Has anyone used any of the following gasket removal sprays? From reputable companies and fairly easy to find.
VHT:
http://www.pjhbrands.com/vht/gasketremover.htm
Loctite:
http://www.loctite.com.au/automotive/gasketremover.htm
Permatex:
http://www.iboats.com/products/7/4116_permatex_reg_gasket_remover.html
Also, have you considered the 3M Scotch-Brite discs? They make "metal prep" discs that will work in drill or pads that attach to a die grinder.
Warren & Ron, may you rest in Peace.
Old 07-30-2003, 01:59 PM
1yearonLy's Avatar
I have a little dremel tool with pads like that but I'm afraid of getting bits of metal in there.
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 07-30-2003, 02:12 PM
