Intermittant power window failure
When I drive home, I open the windows. When I get home, the passenger side window does not operate. Everything else works. An hour later, when the car has cooled down some, it works. They are both on the same fuse.
I was planning on checking the voltage regulator. Any ideas?
Big Hooters and 911's will always be in style |
one of gods prototypes
try pulling the window switches and spraying some contact cleaner in them (or carefully pull them apart), they may just be dusty/dirty, common problem on 15+ year old cars
Brought to you by Carl's Jr. |
Montana 911
relay....going bad? Try a new relay or swap it with the horn relay to test it.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
