backfire
My 1976 911 Targa backfired out the exhaust and stopped running. It turns over but won't start. I assume the timing chain jumped.
Is it possible nothing bent if it only jumped one tooth? Or do I just start ripping the thing apart?
Old 08-27-2003, 04:23 AM
drag racing the short bus
dd74's Avatar
Are you sure it's not the pop off valve? Do you have a pop off valve?
Check under your airbox - the pop off looks like a toilet plunger. It might just need re-seating, which you can do by hand.
Cheaper than "ripping the thing apart."
Hopefully you have one of these valves. Otherwise, you might've blown your airbox.
The Terror of Tiny Town
Old 08-27-2003, 09:31 AM
I agree, likely either an unseated "pop off" valve or a blown air box ($$). I would check the point dwell too as a good "thump" sometimes loosens the points if not they were not properly tightened. Good luck. Jim
Old 08-27-2003, 10:03 AM
Author of "101 Projects"
Wayne 962's Avatar
Do a bunch of research on this site and here (http://www.101projects.com) before you start tearing stuff apart. Sounds like you might have blown your CIS airbox, or at best, blew a hose and you now have a vacuum leak...
-Wayne
Old 08-27-2003, 11:23 AM
It has a pop off valve. It also backfired out the exhaust so it wouldn't be likely to blowup the air box that way. BTW I didn't mean the timing got knocked out with the backfire I ment the backfire may have been the result of a jumped timing chain. EG the plug fires while the ehxhaust vale is open.
Also, I just did a compression test and the right bank is low. So... when I get to pull the covers next week (I'll be out of town till Wed.) can I expect to find the timming out? If I do, is it possible it didn't break/bend anything?
Old 08-27-2003, 08:48 PM
I had a set of points do this to me ( 77s ) about a month ago . I replaced them and the car has run fine since and by the way the points were only about a month old.
Jim
77S
04 Titan
03 Xterra
Old 08-28-2003, 01:47 AM
