For one thing, copper work-hardens and will eventually crack. I forget the second reason; maybe something to do with copper reacting with lube oil? (don't quote me).
You could make the lines out of brass, that's what the factory lines are made of, then silver solder the fittings onto the brass tubes. Sherwood |
yeah brass is good, but copper is real easy to bend, brass very hard. Do you mean that the copper brazing cracks, or the pipe?
I like them I drive them |
If your cooler is a "Modern" setrab or mocal, I have Widemouth fittings that thread directly into the cooler to provide native 30mm metric male connections. These are not an-metric adapters, these are native fittings for the application that I machine. Hence none of the flow restriction issues associated with AN-12 fittings and adapters. I say "Modern" because older setrabs had welded on fittings instead of the modern ones with threaded fittings. My solutions let you build an oil cooling system with high-flow 30mm fittings throughout even with setrab/mocal coolers, just like god and the factory intended.
Chuck Moreland - elephantracing.com - vonnen.com Last edited by Chuck Moreland; 08-20-2003 at 04:38 PM.. |
"....yeah brass is good, but copper is real easy to bend, brass very hard. Do you mean that the copper brazing cracks, or the pipe?"
Copper pipe work-hardens, gets brittle, then cracks. Brazing uses brass or bronze filler rod to join materials together below their melting point. Sherwood |
Re: Follow up
Find a shop that wants to work with you.
