Certified Pre-Owned
BGCarrera32's Avatar
cowtown...YOU ARE THE MAN! Thanks for posting, especially the shot up by the fuel tank.
I'm after clarification on what the fitting adaptor is at the tank return -red arrow- (I can't seem to find the female-to-6AN piece you used there), and are you saying the banjo at the pump is 12x1.5? -green arrow-
[img]
Thanks huge for the pics, this gives me a great idea of what I'm up against. Thanks to John for his words of wisdom as well.
-BG
'84 Carrera Coupe
Old 08-20-2003, 05:27 AM
That adapter is a modified Earl's EAR-9894DBH, 6AN flare to 14x1.5 Female. It is a fuel injection piece that has (had) a long narrow protrusion with an o-ring on it. I bored out the adapter with a drill press, to match the ID of the other 6AN fittings, and got rid of the o-ring and long skinny part. I think I have a picture I can put up later of the before-and-after, if this doesn't make sense. (**EDIT**-I think I got confused here, the one I modified was the 14mm male piece. Female one was used as-is.) The Earl's site might also have a picture of the adapter. I'm going to do a pressure test this week some time, and will shout if something does not work as intended.
On my front pump, the outlet is 12x1.5. But this is a CIS car and you will want to measure your Carrera fittings. Also, I mounted the front pump using factory parts, but it may very well be oriented or placed differently from you car's pump.
Here's a portion of my Excel list that I used to order. Again, don't take it as gospel for a Carrera. Or another '75 911S, for that matter.
Old 08-20-2003, 07:33 AM
Certified Pre-Owned
Excellent! Where did you buy all of your parts?
'84 Carrera Coupe
Old 08-20-2003, 07:46 AM
I split the order based on who had which parts in stock...
www.amfmotorsports.com
www.summitracing.com
www.racerpartswholesale.com
Old 08-20-2003, 08:35 AM
304065's Avatar
I would try to order everything from one place and save yourself a bundle on freight. My next day air tab during my own project was in excess of a developing nation's GDP.
try these guys: www.amstreetrod.com
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-20-2003, 09:26 AM
Oops, that first link should be www.amstreetrod.com.
Old 08-20-2003, 09:32 AM
