blocking off injectors in 2.4 heads, Ideas?
I am done with my CIS and moving on to carbs. They will arive in a few days. But I still need some ideas on how to block off the injectors in my 2.4 heads. I do not want to destroy the injectors or injector fittings. I supose I can cut the fuel line above the injector, clean out the line and put a bolt into the line. Any ideas ?
What thread size are the injectors?? get a plug of the same size.?
The bolt in the line might be dicey, it should be threaded or it will leak, and you sure don't want to be tapping THAT on the car! Remove first! I doubt that the fuel lines are the right wall thickness to tap anyway... |
Check with PMO. I'm sure they have them.
you could just leave the injectors in place, or find/make a tee shaped plug that will push into the original injector grommet. maybe just some cutoff clutch head screws. just so they fit tight, like tap with a hammer to get them in. i guess you don't want to kill the metal injector sleeves in the heads.
| All times are GMT -8. The time now is 06:32 PM. |
