Pragmatic Dreamer
larry47us's Avatar
Compression Test - Leakdown test or both?
If they do a compression test on a car, and the numbers all fall within 7% of each other (within the guidelines that Wayne has set in his book of 15%), is there any reason to do a leakdown test?
Does a leakdown test do more than tell you where a particular cylinder is leaking? Rings, intake valves or exhaust valves?
On the car I am looking at, the compression runs from 140 psi to 152 psi. But, the leakdown runs from 9 - 19%. Should I have the leakdown redone, or are the quality of the compression numbers sufficient to know the engine is solid?
thanks
larry
2004 - 911 - 996 Targa - Dark Teal Metallic, with Natural Brown Leather interior.
1973 - Viper Green 911E Targa - Kermit - gone but not forgotten
Kermit's Short Story and Pix 911E Website
Early 911S Registry Member #537
Old 08-24-2003, 07:59 PM
