Ho Hum 74's Avatar
What size spacers to fit 944 rear wheels with oil lines?
I fitted my oil cooler this weekend and found out (obviously) that my rear wheels do not fit without rubbing severely on the oil lines. I have 944 (951) offset 8" rears. Any ideas what size spacer to use to clear my oil lines? Anyone else had this experience?
Thanks in advance.
Tristan
Old 08-25-2003, 03:03 PM
Bill Verburg's Avatar
If the info requested here was available this question would be a lot easier to answer.
Bill Verburg
Old 08-25-2003, 03:43 PM
Ho Hum 74's Avatar
If I was at home and not on the road working on a major proposal then I could do that! I just thought someone else may have had the same challenge. I have a track date 1st weekend in Sept.
Old 08-25-2003, 03:47 PM
In that case, 12.7mm wil give you a fit identical to regular 911 8s. I still need the other data though.
Bill Verburg
Old 08-25-2003, 03:50 PM
Ho Hum 74's Avatar
Now that's what I call a response! Many thanks Bill.
Old 08-25-2003, 03:52 PM
