Weekend Project...
Killed some surface rust on my fender.... fairly straight forward... but I am proud none the less.
1979 911 SC Targa
Old 08-25-2003, 02:07 PM
Administrator
Jack Olsen's Avatar
Looks like it was a multi-generational project.
Old 08-25-2003, 02:19 PM
Shouldn't you make fix your seatbelt before you worry about the paint on your car?
www.akalikoskateboards.com
72 3.0 RSR flared Targa
Old 08-25-2003, 02:20 PM
Smile
No Jack not multi-generational.... just a good buddy with a great family looking to help a kid out...
1979 911 SC Targa
Old 08-25-2003, 04:43 PM
the guy in the pics is actually Martin he has a little project of his own going on.... little more elaborate
http://www.2002tii-restoration.com/
1979 911 SC Targa
Old 08-25-2003, 04:50 PM
ipapilot's Avatar
I'm still waiting for the all finished pics! Post again when you get it all buffed out. Did you use a BC/CC or single stage?
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 08-25-2003, 06:40 PM
david914's Avatar
Nice job! Can't tell for sure, but what color is it? You'll have to take some more pix outside when you get a chance!
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 08-25-2003, 06:49 PM
Senior Member
john_colasante's Avatar
I noticed you masked off a section. How do you blend the paint with a hard line like that?
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 08-25-2003, 07:04 PM
The color match I was a bit disappointed in as Advanced Paint of Denver really didn’t do what I had asked them... (To get a perfect match.) However I will be doing some color sanding around the edges to try and blend the paints a little better. Originally I took on this project to protect my investment by not letting the rust dig any deeper in that fender. So I must say it is a success either way as I managed to kill all the surface rust (which was quite extensive) and none of this would have been possible without the help of Martin as he truly is a magician in the shop. Our next step may be to try and get a better match of the paints (new paint is a bit flat, not as metallic as the rest of the car.) Then head back into for a quick spray down. I will post pics after I get the color sanding done. We also may have laid the metallic silver on a bit thick originally causing the metallic flakes to sink however that is still just a theory of ours. I will keep you posted on this project as well as many projects to come in the eternal quest to keep the Targa looking sharp.
1979 911 SC Targa
Old 08-26-2003, 04:56 AM
