-   -   Speed sensor signal: Question for Experts (http://forums.pelicanparts.com/porsche-911-technical-forum/125871-speed-sensor-signal-question-experts.html)
ChrisBennet 09-03-2003 10:30 AM
I used my oscilloscope to look at the speed and reference signals for my 3.2 911 and a 944. The reference signals had the spikey look I was expecting but the speed signals looked like a sine wave - not like the sawtooth the manuals show.
Could someone who has looked at these signal before comment on what they should look like?
thanks,
Chris
Early_S_Man 09-03-2003 10:41 AM
Chris,
Sounds like the speed sensor needs to be adjusted to the proper air gap. Try adjusting the gap and take a look to see if the waveform doesn't change to the expected shape ...
ChrisBennet 09-03-2003 10:55 AM
Originally posted by Early_S_Man
Chris,
If that was the case, would both car's signals look the same (944 and 911)? I'm thinking it might be something to do with my measurement technique.
-Chris
BGCarrera32 09-03-2003 11:20 AM
Not necessarily. The ref signal might but I recall reading somewhere that the 944 flywheel has more teeth on it than the 911's, even though the DME is similar and the sender is the same... (You may know more on that than I do)
-BG
ChrisBennet 09-03-2003 11:51 AM
Perhaps a picture will help.
http://forums.pelicanparts.com/uploa...1062614901.jpg
I did notice that my speed signal wasn't very strong. Less than .5 volts I think. Car runs fine though which leads me back to my measurement technique being wrong theory.
-Chris
BGCarrera32 09-03-2003 12:20 PM
Can you change the range and sample rate of your scope? If the upper peak to lower peak range on your display is decreased to say 2.0V max, and the sample rate display is narrowed, it may look more like the book. What does the book list for values against the graph that you show from the book? I'd be suspect of the book anyway...
If you think you have weak signal, what are you getting for a VAC value from the speed sensor?
BGCarrera32 09-03-2003 12:26 PM
O.k., duh, I just reread your post. I get like 2 VAC at the proper .8mm gap. Every tiny distance you move that sensor face away from the flywheel, the AC current generated by the sensor drops off exponentially. I tried this once by mounting the speed sensor to the toolpost holder on my lathe, and moving the face closer and closer to the chuck face. Got up to like 3.5V with the big chuck teeth and almost no gap.
What I was getting at in my previous post was that even though your graph looks different, it could be just displayed different (duh) even though peak to peak measurements are really the same, so we need to see values...
ChrisBennet 09-03-2003 12:29 PM
Good idea(s) BG. I'm going to make up a test plug and try again, maybe this weekend. I'll let you know what I find. That plug is right near the coil and spark plug wires. I've have some shielded wire, I just need a plug from the local Metric hardware place...
-Chris
Early_S_Man 09-04-2003 07:31 AM
Chris,
It is very possible that the bandwidth of the scope you were using is responsiblr for the sine wave display, rather than the sharp waveform you expected. If the scope is a relatively inexpensive model with bandwidth under 1 MHz, then that is the problem. Many scopes these days do not have the bandwidth to accurately display complex waveforms -- any 'sharp' waveform components require bandwidth many times higher than the fundamental frequency of the basic 'rep' rate.
Even a 500 MHz scope displays a sine wave when fed the sharp waveform from a time mark generator at the 2 ns setting!
ChrisBennet 09-04-2003 07:48 AM
Warren,
The scope is a Fluke 192 (60Mhz). That should be OK shouldn't it? I was using it in "auto" mode. I'll try some manual settings and see if that helps.
-Chris
Early_S_Man 09-04-2003 08:22 AM
Chris,
Yes, 60 MHz should be adequate, but, were you using simple wire & clip leads into a banana plug ... or a 'proper' 10:1 compensated & shielded scope probe?
ChrisBennet 09-04-2003 08:24 AM
Chris,
I was using the sheild probe that came with the scope. I'm not sure if it is 10:1.
-Chris
