Irrationally exuberant
Speed sensor signal: Question for Experts
I used my oscilloscope to look at the speed and reference signals for my 3.2 911 and a 944. The reference signals had the spikey look I was expecting but the speed signals looked like a sine wave - not like the sawtooth the manuals show.
Could someone who has looked at these signal before comment on what they should look like? thanks, Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris,
Sounds like the speed sensor needs to be adjusted to the proper air gap. Try adjusting the gap and take a look to see if the waveform doesn't change to the expected shape ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
-Chris
Certified Pre-Owned
-BG
'84 Carrera Coupe |
Perhaps a picture will help.
I did notice that my speed signal wasn't very strong. Less than .5 volts I think. Car runs fine though which leads me back to my measurement technique being wrong theory. -Chris
Certified Pre-Owned
Can you change the range and sample rate of your scope? If the upper peak to lower peak range on your display is decreased to say 2.0V max, and the sample rate display is narrowed, it may look more like the book. What does the book list for values against the graph that you show from the book? I'd be suspect of the book anyway...
If you think you have weak signal, what are you getting for a VAC value from the speed sensor?
'84 Carrera Coupe |
Certified Pre-Owned
What I was getting at in my previous post was that even though your graph looks different, it could be just displayed different (duh) even though peak to peak measurements are really the same, so we need to see values...
'84 Carrera Coupe |
-Chris
Chris,
It is very possible that the bandwidth of the scope you were using is responsiblr for the sine wave display, rather than the sharp waveform you expected. If the scope is a relatively inexpensive model with bandwidth under 1 MHz, then that is the problem. Many scopes these days do not have the bandwidth to accurately display complex waveforms -- any 'sharp' waveform components require bandwidth many times higher than the fundamental frequency of the basic 'rep' rate. Even a 500 MHz scope displays a sine wave when fed the sharp waveform from a time mark generator at the 2 ns setting!
Warren,
The scope is a Fluke 192 (60Mhz). That should be OK shouldn't it? I was using it in "auto" mode. I'll try some manual settings and see if that helps. -Chris
Chris,
Yes, 60 MHz should be adequate, but, were you using simple wire & clip leads into a banana plug ... or a 'proper' 10:1 compensated & shielded scope probe?
-Chris
