915 First Gear Survey
I'm just getting the hang of the double clutch downshift into first after a year. If you've got a 915, please post the year of trans, miles on trans (since rebuild if applicable), and whether you need to double clutch to get into first on the roll. Also whether any other synchros are bad.
1977 (magnesium?) 208K bad first synchro, rest OK.
1977 911S Targa 2.7
Old 06-09-2003, 11:56 AM
Non Compos Mentis
No need to double clutch here. My '73 has about 100 miles since rebuild.
Old 06-09-2003, 11:58 AM
zymurgist's Avatar
My tranny is a 915 out of an SC, about 30,000 miles on it. I don't even try to put it into first gear on a roll... if I'm rolling, my engine has enough torque to get me going.
Ken
1974 Porsche 914 2.0 "Babydoll"
Old 06-09-2003, 12:02 PM
Ken- My car can definitely go in 2nd from 5 MPH, or even from a start, but it doesn't like it (chugging etc until at least 1500 RPM). 2.7 CIS
Will your car pull away smoothly?
1977 911S Targa 2.7
Old 06-09-2003, 12:07 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
my 915 shifts very well...no problems with the tranny in the two years I have owned the car, not sure when rebuild was done.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-09-2003, 12:10 PM
Autodidactic user
David E. Clark's Avatar
No downshifting to first for me either. The early cars are pretty light so I haven't had any lugging problems in second -- even at 5mph. But to answer your question, I have about 138,000 miles on my 915 transmission and the first gear syncros are definately showing their age. I sometimes have to "double-clutch" from a standstill. It's nothing I worry about however.
'73 911E Targa (MFI)
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 06-09-2003, 12:25 PM
Siena911's Avatar
I don't even try to shift into 1st without being at a complete standstill. On the to do list, I tried double clutching once, and just could not get it right, never tried since then. SC with 136000 miles on it, motor upgrade to 3.2 about 15000 miles ago, all other synchro's seem fine, i.e. no grating or jumping out of gears
Cheers Jakes
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
I could be wrong, but I think that the pre '75 cars also benefitted from a lower overall second gear than the later cars due to the R&P change?
Lightweight plus lower gears = : )
1977 911S Targa 2.7
Old 06-09-2003, 12:27 PM
magilla's Avatar
I have an '83 SC with no rebuilds and 102k on the clock. I can rarely get into first while rolling, and second is pretty worn, as well. I will address this this winter, I hope.
'83 SC Coupe- Blk/Blk
'03 Daughter- 10fingers/10toes
Old 06-09-2003, 12:36 PM
I have an '84. The 915 has about 1500 miles on a rebuild. I always double-clutch when downshifting, no matter what gear. But I rarely go down into first on a roll. It will go into first on a roll now, though, whereas before the rebuild it definitely would not.
I don't know much about transmissions, but it seems the syncros in a 915 are barely adequate by design.
~Hugh
'84 Carrera
n8marx's Avatar
'86 Carrera, 915 rebuilt at 87,000 miles, currently at 100,800 miles. If I so desire I can shift into first at anything less than about 10 mph. I usually don't desire though. Better to wait until I'm stopped. I don't wish to rebuild this thing any sooner than neccesary.
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 06-09-2003, 12:40 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
In the middle of rebuilding trans and top end on motor at 140,000 (really stupid ***** was the cause). Trans had problems shifting into first while rolling but as long as it wasn't cold, it was possible. Upshifting into second was terrible though.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-09-2003, 12:50 PM
Send a message via Yahoo to 911Brian
Mine is an 80 and has about 30k mi since rebuild. First gear is flawless on a roll. I have some minor probs shifting into 2nd from 1st, a little hard at times, no grinding. I installed shift bushings and that made a difference. I plan on changing the gear oil to Swepco soon as well as adjusting the clutch and possibly adjusting the linkage. So far so good
Brian
86 Carrera Red/Black
80 SC Coupe Silver/Black (gone but not forgotten)
Old 06-09-2003, 01:05 PM
Sonic dB's Avatar
Mine is 86, 65000 miles original tranny. I can sometimes get it into first on a small 3-5 mph roll...but I dont even bother. From a stand still, I have to depress the clutch and wait a good full second before attempting to put it into first...OR, more likely due to drivers waiting behind me, I "tap" it into 2nd then go into first. If I dont do either of those things and shift into 1st too quickly from a stop, then I get Crunch.
2nd gear is fine as all the rest.
Old 06-09-2003, 01:10 PM
Send a message via ICQ to old_skul
I've put about 40,000 on my car since I had a rebuilt tranny put in. No problems downshifting into first from a 20mph roll. No double clutch required.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 06-09-2003, 01:19 PM
nice doggie
Hetmann's Avatar
Mine has about 500 since its rebuild. It is shifting well with no double clutching required. I can downshift into 1st, if done gingerly, but as a general habit I never do when I'm rolling.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 06-09-2003, 01:56 PM
JavaBrewer's Avatar
1986 with 40K miles on rebuilt transmission. No problems going into 1st when fully stopped, 2nd can be difficult if I rush it. The only time the car's in 1st is when pulling away from a full stop. Rush hour traffic and it stays in 2nd - pulls nicely from just rolling speeds and up.
Old 06-09-2003, 02:11 PM
zymurgist's Avatar
Honestly, I'll have to check. I've only owned it since December (my first Porsche!) and I only drive it on weekends.
When I am stopped at a traffic light, I normally put the transmission in neutral and let out the clutch. Before I have to start out, I shift into 2nd and then back to 1st. Otherwise it crunches a little bit going into first. I think I may have a clutch cable issue here.
Ken
Old 06-09-2003, 02:12 PM
'78 SC, 98K miles, no tranny rebuild that I'm aware of. Down shifting into first (at anything less than 20 MPH, I haven't tried at any faster speed, no need to) takes some technique but is not difficult. Shift to neutral, begin to move shifter to first gear position, blip the throttle (amount of rev. depends on how fast your going) and the shifter slips right into first. I could (I did when I first got it and still do occasionly) double-clutch, but it's not necessary and the result is the same. But you must "feel" with the shift lever when it's about to move into first (just before it "grinds") and if you blip the throttle right it feels like it just sucks the shifter into first.
Jerry M
'78 SC
Old 06-09-2003, 02:21 PM
CHILI's Avatar
I changed all 5 syncros on my 74 915 tranny about 5K miles ago. Can't go into 1st on a roll either. Going to second before first helps since both gears are on the same clog. At least it gets the clog moving. I just use second gear like the others, esp since I have the low ring-an-pinion. More than enough torque. Check out Wayne's 101 projects. If I remember correctly he has a section on rebuilding first gear. I figured I'd just do all 5 since the syncros aren't expensive.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 06-09-2003, 02:33 PM
