-   -   Unusual Tachometer Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/126493-unusual-tachometer-problem.html)
Adidas 09-08-2003 09:09 AM
On my 75 911S, the tachometer has a low output. While the car is idling or running the tach reads around 1000rpms lower or slower than it should. This is not a low idle speed problem where the engine is running too slow. This is a low reading on the tach where the engine is running at a faster rpm than what the tach reads. I've cleaned the ignition points and checked the dwell both are ok.I've also checked the rpms with a hand held tach which reads around 1000rpms faster than what the tach shows. Could this be a short in the wiring somewhere or a bad cd unit. Could someone walk me through a logical way of checking things out. I have a digital multimeter and don't mind trying to trace this thing down. Any help appreciated. Bill
POVI 09-08-2003 09:16 AM
Quickest thing is .... to get with a freind and swap out tach with his .. only takes 5 min , and you know right away if problem is with in tech unit
Joe
