SRISER's Avatar
Exclamation Which way do ya turn the bolt?
Trying to lower the rear of the red blurr using the eccentric bolt. Okay, hands up, which way to do you turn it to lower? .75 inch is all I want, really, I can live with it...for about a month when I will NEED to have it even lower.
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 09-09-2003, 05:15 AM
n8marx's Avatar
Once you loosen the nut that secures the eccentric bolt it shopuldn't matter which direction you rotate the bolt itself. It is not threaded in anyway. With all of the weight off of the rear end (ie. rear end jacked up) you should be able to rotate the eccentric bolt in both directions until it does what you want it to do. You will need a very thin wrench to get on the back side of the bolt though. Standard wrench was too thick for me. I had to loosen up the torsion bar cap a bit and slide it out in order to get my wrench behind the spring plate.
Good luck.
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 09-09-2003, 05:31 AM
SRISER's Avatar
How much adjustment were you able to get out of it? I have the G50 tranny and wonder if that makes any kind of difference...
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 09-09-2003, 05:36 AM
Friend of Warren
total adjustment is around 1"
Kurt V
Old 09-09-2003, 05:47 AM
Kurt:
Can you confirm that?
Spec books and such indicate around 3/8-3/4" total adjustment range. However, this could mean the slotted range, and not the total effect at the wheel, which is further away. Hmm.. maybe the 3/8-3/4 at the slot equates to 1" in absolute ride height.
Inquisitive minds want to know !
----Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-09-2003, 12:34 PM
Friend of Warren
Just based on my own observations when making the adjustment on my '86 Carrera.
Kurt V
Old 09-09-2003, 12:50 PM
SRISER's Avatar
I tried today. Couldn't get the bolts loose...I guess I will have to hit up the NoVA gang and see if they can help...1" is just enough...until I need to drop it more...
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 09-09-2003, 12:56 PM
