At first I thought it might be the column mounting bolts because there was so much play and it was more up/down then left/right. The bushing did eliminate the movement, so in my case it wasn't the mounting bolts.
However, I understand the mounting bolt problem can be serious because it can loosen to the point where the steering column just falls down altogether. |
| All times are GMT -8. The time now is 02:23 PM. |
