Porsche Crest Steering column play
I purchased a 1989 Carrera about a month ago - great car in nice condition. Just today I began to experience a lot of play in the steering column - about 1 inch up and down and 1/2 inch left to right. There is no play in and out, and the steering response is still fine. The steering wheel now shakes when going over the slightest bump. This came on all of a sudden, as if a bracket just became loose.
Any ideas on what may be causing this?
Old 09-10-2003, 10:02 PM
MOMO3.2's Avatar
DaveJ911:
I bought an 87 Carrera a couple months ago and it has a little play as you describe too. I have been trying to pretend it is not there. I will be curious to see what people have to say.
It does not feel like a steering box or tie rods. It is the actual column.
Mike
Old 09-10-2003, 10:10 PM
scottb's Avatar
Do a search on the board, and you'll find your answers.
As I understand it, there's a bushing in the column that fails over time. You have to remove the steering wheel, and all you do is push the new bushing on, leaving the old one to slide down inside the column. From what I've read, there's no need to remove the old one. I'm sure our host sells the bushing.
I think it's a pretty common problem, with an easy fix.
1984 Targa
Old 09-10-2003, 10:59 PM
bigchillcar's Avatar
Yep, Pelican sells the bushing and there's even a technical article on this website to explain how to do the r&r. The original bushing was plastic, the replacement is metal and not expected to fail. Good luck!
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 09-11-2003, 12:46 AM
nostatic's Avatar
I just did this fix...very easy to do.
Old 09-11-2003, 02:02 AM
You want Pelican part F-347-739-02.
Doesn't remove all the play, but get rid of the slop from a broken factory plastic bushing.
'76 2.7-->3.2
Old 09-11-2003, 01:06 PM
Funny, same thing just happened to mine the day before yesterday. Was working fine with zero wobbles and pow all of a sudden the wheel got real sloppy. I've ordered a new bushing along with a new bearing kit that Pelican also sells.
1978 widebody targa
Old 09-11-2003, 02:00 PM
At first it seemed like there was too much play for it to be the bushing, but I took off the steering wheel and it looks like that is the problem. I just ordered the Qwik-Fix Sleeve.
Thanks to all for the help.
Old 09-11-2003, 06:15 PM
motion's Avatar
Yeah, but you have to remove the old broken up bits.. don't leave them in there.
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 09-11-2003, 06:39 PM
part# 928 347 739 02
206 637 4071
Old 09-11-2003, 06:46 PM
n8marx's Avatar
The "quick-fix sleeve" referenced above is actually a metal 928 part that serves the same purpose. John Walker's part number is the part I used to solve this problem a week ago. Good as new.
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 09-11-2003, 08:49 PM
ricwon's Avatar
Send a message via Yahoo to ricwon
yeah, I had the same problem in my car a couple of months ago. Lucky for me my turn signal switch went out about the same time, so I had a two-fer
86 911 carrera targa
83 911 sc targa, totalled
01.21.13 end of an error.
Old 09-12-2003, 12:56 AM
n8marx's Avatar
ricwon,
When you say your turn signal switch went out, what did it do? At the same moment my steering column slop appeared my turn signal switch began acting funny. If I have the headlights turned on and use the signal, the high beams come on when the signal cancels. Is this what yours did? Just trying to decide if the column wobble broke the switch or was it worn before and I just now noticed it?
Nate
Old 09-12-2003, 12:49 PM
scottb's Avatar
N8: My guess is that it's a bad coincidence. Your switch is displaying the classic symptoms of failure. Since you're going to have to take the wheel off to fix either problem, I'd do both at the same time. Our host sells the parts.
Scott
1984 Targa
Old 09-12-2003, 12:54 PM
n8marx's Avatar
Trouble is I've already replaced the bushing. Oh well, getting the wheel off is no large task.
So, as long as I'm putting a new switch in, where do I get that relay kit? Does Pelican sell that too? I know most of you make it yourselves but, while mechanically inclined, Thomas Edison I am not. The fear of a smoldering 911 forces me to leave the electronics to those more qualified.
Nate
Old 09-12-2003, 01:00 PM
scottb's Avatar
Do a search on the board for "sucro". Marcus Sucro sells a kit for about $20. I don't think our host sells something similar.
1984 Targa
Old 09-12-2003, 02:43 PM
ricwon's Avatar
Hi Nate, My steering wheel started getting slop in it. I could move it up and down about 1/2 in. Then soon after that I was leaving work, turned my headlights on and all I got was the parking lights. I was able to get home by holding the turnsignal switch in the hi-beam flash position. I originally thought that it was a faulty headlight switch, but after researching the pelican archives determined that it was probably the turn signal switch. I bought the switch and column bushing from our hosts here and also installed the marcus sucro relay. These parts seemed to completely fix the problems and my headlights seem brighter but that could be my imagination The relay is a good upgrade especially if you are running higher wattage bulbs. ric
Old 09-12-2003, 04:14 PM
Just to close this one out: I installed the steering column bushing and it did the trick. Good as new.
Old 09-29-2003, 08:35 PM
scottb's Avatar
Thanks for the follow-up. Congrats!
1984 Targa
Old 09-29-2003, 11:01 PM
Typical Fish's Avatar
I want to add to this. only because I have a slightly different experience. I, too had up and down play, and was told it was the bushing. It was actualy the COLUMN MOUNTING BOLTS directly behind the tachometer allowing the whole column to shift up and down by about a quarter of an inch.
Matt
Old 09-30-2003, 12:58 AM
