limble's Avatar
removing carbon deposits
In the process of removing carbon deposits on a 2,2 engine.
Any tips?
One suggestion was tape off everything except the dome of the piston and dry blast with a soft media (glass beads).
What about the valves?.
I would like to do as much at home prior to turning it over to the machine shop.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 09-11-2003, 10:24 AM
soak it in carb cleaner.
Old 09-11-2003, 10:29 AM
I just did the same clean up. On the pistons I soaked upside down in kerosene overnight. Then with a fine emery/wet &dry gently rubbed the top of the piston. I used kerosene as the lubricating media. Came out really nice.Depending of how hard the carbon is you may have to start slightly coarser. On the valves, I tried all the soaking routes, carb cleaner, coke etc. The exhaust valves put up a good fight. Ended up masking the stems with duct tape and chucking them in a drill and gently abrading until I had cleaned them up. Came out pretty good. Take care though. Could've taken them to be blasted but I operate on the premise that I will only part with any of my parts only if absolutely necessary.
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 09-11-2003, 10:42 AM
Early_S_Man's Avatar
Porsche Crest
Specifically, Berryman's Chem-Dip! It wouldn't hurt to brush and turn over the piston a few time during the soak to give 'fresh' cleaner access to the carbon and lead deposits ... aeration/bubbles from a steel line submerged under the piston and supplied with air from an aquarium pump could keep the cleaner moving and improve the rate of loosening. Be sure to wear long-cuffed, heavy-duty rubber gloves and apron while handling the piston around the Chem-Dip ... or you will be running for a faucet in pain when it gets on your skin!!!
Rinse off with water and bristle brush should remove the carbon very easily. Good luck!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-11-2003, 10:54 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Don't forget to wear nitrile gloves!!
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 09-11-2003, 02:00 PM
