Ashtray bulb type?
When I got my car the bulb for the ashtray was burned out. Unfortunately 1 yr. later I've lost the bulb and finally want to replace it. If I go to an autoparts store what do I ask for?
On a similar note, does anyone have a photo of where the lights go under the dash? I have a few lights hanging down and have no idea as to where they should be attached.
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 09-11-2003, 01:41 PM
Actually I just disconnected mine to use the juice to illuminate a CHT gauge I just installed where the ashtray went. If no one else answers, I'll dig it up when I get home later tonite and let you know. The only other dangling light I found behind the dash appeared to be there to illuminate the heater controls (I never did find a bracket for it but didn't look too hard as I used the juice from that one to illuminate a new Voltmeter right next to the CHT gauge. )
Argo
88 Targa
Old 09-11-2003, 01:56 PM
It's a spring-loaded/push-in and rotate type (with 2 tabs on the side rather than the usual 2 round nubs at the bottom) with a 1/4" base diameter and 12829PHILLIPS12V2W _ A7 written on the side. It fits into a removable socket (with 2 female connectors) that slides into a fixed base mounted on top of the ashtray mounting framework. It's from an '88 so yours should be the same set up. Hope this helps.
Argo
88 Targa
Old 09-11-2003, 07:35 PM
Cool. Thanks a lot!
Old 09-11-2003, 08:17 PM
