2.2E spec. questions..
Was the 2.2L ever installed in 1973 911's? I thought the 2.4L was the only displacement that year?
What HP did the 2.2L E spec provide. An engine I am looking at, is stated to be a '73 2.2E with MFI. Thanks for your help! Chris |
2.2E was used in '70 and '71. It is NOT the correct motor for a '73. HP rating of a 2.2E is 155.
The engine number will tell you what it started life as.
A 911E engine number should be 62X yyyy 6 for 6 cylinder, 2 for 911E (911T could be 61 or 65, 911S is 63) the number at X is the year, 9=69 (2.0 Liter) 0=70, 1=71 (2.2 Liter) 2=72, 3=73. (2.4 Liter) yyyy is the sequential serial number. Hope this helps, Tom |
thanks guys for the info! I will ask the seller the engine number and the engine type number.
Thanks again! |
This looks to be a 1971 2.2. I dont think this case would have piston squirters? Prolly a 3R case?
Not sure what this engine would be worth since one had to assume it would need rebuilding. your thoughts? |
A '71 should have piston squirters.
I would think it is probably worth $1000 if it is in need of a rebuild and the MFI is intact.
| All times are GMT -8. The time now is 04:10 AM. |
