| Registered |
			Great set up, but with a different brand apex coupler and the Seine Systems gate keeper.  I too vote for the Seine System for the savings.  I have had one on my SC for a little over a year.  Best upgrade I made to my car, next to the 3.6.   Somehting else you may want to do to really tighten up the shifting/torque is to use solid rear motor mounts and the sport mounts at the trans. Coupled with what you have already done, solid/sport mounts will better improve the shifting and feel of the car even better!
				__________________ .. | ||
|  09-22-2003, 07:41 AM |
| Registered | Quote:
				__________________ 2014 Porsche Cayman S 2001 BMW 525i Touring 1996 Porsche 911 (Gone to Germany) '86 911 Carrera (Gone to Aruba) | ||
|  09-22-2003, 08:34 AM |
| Registered Join Date: Feb 2003 Location: D.C. Suburbia
			I have the Seine Systems gate shhift on my car, along with a factory short shift, and I love it. I don't see anything the Robotek has that the Siene System unit doesn't, except a higher price tag. In fact, it doesn't look like the Robotek has a spring relief tab for 1-2 gears like Siene Systems. Can anyone verify if this is true?
				__________________ Chris M 1985 911 Carrera w/ 3.6 | ||
|  09-22-2003, 09:38 AM |
| Registered | Quote:
|  09-22-2003, 10:23 AM |
| Registered Join Date: Aug 2001 Location: SoBay, SoCal
			Which kit (Seine?) requires use of a hose clamp?  There was a thread about a year ago about a shift kit that was good, except that it requires use of a 15 cent hose clamp, and that issue raised concerns. So what other parts should be changed? Shift bushings? thanks Mike '86 coupe
				__________________ Mike '86 911 coupe '85 BMW 535i '11 Cayenne | ||
|  09-22-2003, 12:00 PM |
| Formerly bb80sc Join Date: Aug 2001 Location: Hollywood Beach, CA
			Mike, the Seine system uses the hose clamp.  I used the clamp, along with JBWeld and it'd been fine.  Yes, along with this mod, replace all bushings, including the shift coupler bushings, and get the linkage properly adjusted. -B
				__________________ Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited | ||
|  09-22-2003, 12:10 PM |
| Registered Join Date: Feb 2003 Location: Black Rock, CT
			Looking at this picture, where's the hose clamp?? Or is it only used in certain applications....if so, which?
				__________________ Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] | ||
|  09-22-2003, 12:33 PM |
| Registered |
			It would be used where the tabs are attached to the shift level.  In the pic the tabs are welded on.  I used the clamp and epoxy and have had no problems.
|  09-22-2003, 12:47 PM |
| Registered |
			You can see the hose clamp being used in the installation directions... "4. Install the Gate Shift arm on the shift lever using the supplied clamp, then adjust engagement between arm and carrier plate "tabs". Note: The clamp provided in the kit allows temporary positioning of the Gate Shift Arm on the shift lever. We recommend tack welding the arm in place after initial installation and adjustment."  If I do get this, I'll probably get my mechanic to install it. I'm somewhat queazy about drilling the mounting holes.
|  09-22-2003, 12:54 PM |
| SCWDP- Shock and Awe Dept |
			If the mount holes are the only thing you are worried about, go for it.  It's really a piece of cake. I welded the arm on, but it's been used by many for quite a while w/ the clamp, w/o problems.
				__________________ Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue | ||
|  09-22-2003, 01:37 PM |
| Registered |
			Not that I'd admit this elsewhere or for any other application. . . . but. . . . JB weld reinforced by the clamp serves well here.
				__________________ Mike - PBG, FL '14 958 Cayenne GTS '05 997 C2 - SOLD '79 911 SC Widebody PCA, NASA, PBOC - SOLD 2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3 | ||
|  09-22-2003, 02:57 PM |
