SLR SLR is offline
SLR
Shift coupler bushings???
Just looked again at my gear shift coupling under the rear cover in the back of the P car and there is a bit of side to side movment. Is there ment to be any movment there and if I need to replace the coupler can I just replace the bushing?. I had a look at Pelican Parts list and there is what they term as sharft coupler bushes. Is this what I need to order?
I'm in the UK so just to call is not on
Cheers Steve
Old 09-15-2003, 05:34 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
The original coupler had an elongated bushing hole. When I removed mine I assumed it was wear, but after breaking the coupler and oredring a new one, the new bushings has the same elongation. Supposedly this was to absorb any of the vibration from the transmission to the driver. The replacement bushings do not have this elongation. Not sure if they make much difference?? After breaking the first one I was not in a hurry to replace the bushings!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 09-15-2003, 06:07 AM
Send a message via ICQ to old_skul
Pelican carries a set of bushings which do not have the elongated holes. They feel a tad more tight than the OEM bushes. The reason the factory made the holes elongated was to reduce noise in the cockpit from the transmission. By elongating the holes, they reduced the amount of vibration transmitted to the shifter.
I don't notice that it's all that much louder.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 09-15-2003, 06:13 AM
If you know anyone with a small lathe, you could just make some out of brass, they work great!
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 09-15-2003, 06:25 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
OK, am i missing something, i'm aware of what bushing your talking about, but i thought the ones there were pretty damn hard. Why would you replace them?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 09-15-2003, 06:36 AM
The coupler bushings are made of medium hardness plastic and they wear.
Mark Szabo
Old 09-15-2003, 06:46 AM
Because the dissentigrate over time, then there is no bushing and no gear selection! They are not as good as solid metal, consider the difference between a monoball suspension bushing and poly bushings.
Old 09-15-2003, 06:47 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I made a new set out of Delrin (black acetal plastic).
Nice tight holes..no slop...work great.
Bob
Bob Hutson
Old 09-15-2003, 06:49 AM
atlporsche's Avatar
I fortunately had a replacement coupler when my original 1967 bushings went south...I was able to dig the reminants out with a screwdriver...they felt like wax. I have a coupler that could use a set of bushings now...when the next set goes I'll be getting nice brass ones.
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 09-15-2003, 06:56 AM
AES AES is offline
I just did a quick search, where this thread showed up!
Shifter Improvements
Old 09-15-2003, 07:53 AM
You can replace the bushing without replacing the coupler. Mine was worn also. I recommend buying the complete kit from Pelican, as I did, and enjoy the improved shifting.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 09-15-2003, 09:40 AM
