canna change law physics
red-beard's Avatar
Sun Roof wind Noise
There is a small metal flap/strip that pop up when I open the sunroof on the 1982 SC. This seems to generate a lot of noise on the highway. I can put my hand up and rotate it down and the noise level drops off. Is this supposed to pop up? Is there a way to keep this down?
James
James
Red-beard for President, 2020
Old 10-10-2003, 10:09 AM
Information Junky
island911's Avatar
You can take it off; but realize it does have a purpose.
Its intent is to produce a small amount of turbulance (to the air) . ..with it off you will experience some nasty low freq. resonance. (at certain speeds, your cabin becomes a kind of giant whistle). This resonance can usually be defeted by cracking a window (or 2) open.
Old 10-10-2003, 10:29 AM
red-beard's Avatar
Hmmmm. I supposed I can fabricate a clip to hold it down. This just seems an in elegant solution.
James
Old 10-10-2003, 10:42 AM
Information Junky
island911's Avatar
Believe me, I've had the same thoughts. At freeway speeds, it really makes a lot of noise.
I know that some of the later Carreras got a supposedly improved version (air-deflector).. .don't know if it's all that much better, but I do know you can udate an SC with that version.
Old 10-10-2003, 10:51 AM
gerard vaglio's Avatar
You guys have inspired me to experiment.
I’ve always thought the sunroof air foil, I just made that name up, is too noisy so this afternoon I decided to take it off. Removing it only takes a few minutes and I ran a quick errand afterwards. I only got the car up to 60mph, but here is what I noticed.
As you might expect, with the sunroof open the car is much quieter now. However, a very pleasant, unexpected benefit was better air circulation in the cabin. The air has always been a little still in my sc even with all the windows open. It was fun to feel a little breeze which helps contribute to the overall feeling of movement as your going down the road.
Next outing I’ll go on the freeway and see what happens when I go a little faster.
If you read any stories in the newspaper of a guy sucked out of his car you’ll know it was me.
Old 10-12-2003, 10:00 PM
air deflector
James my 82 sc deflector sticks in the down pos if you want to trade let me know? I pull it to the up pos when I drive to me the noise isnt an issue I just turn up the tunes
Old 10-12-2003, 10:11 PM
Cool
my stock deflector makes more noise than my brothers '88.. and I've spent weeks traveling in that car.. so I have a new/old Carrera deflector that hasn't been installed yet.. I never thought of removing it till now.
The wind noise is unwanted distorted tunes IMO.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-12-2003, 11:41 PM
Cool
yeah huh..
what about leaving the rear quarters open?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-12-2003, 11:44 PM
Now in 993 land ...
aigel's Avatar
I have the perfect solution: Broken sunroof mechanism. Will never open!
G.
81 SC (sold)
Old 10-13-2003, 12:22 AM
What if you drilled a series of holes in the deflector ? Would this make the wind noise quieter and still allow the deflector do it's intended job ?
Jim
77S
04 Titan
03 Xterra
Old 10-13-2003, 04:19 AM
red-beard's Avatar
In a word - no
Nope, this thing just needs to lay flat when not needed.
James
James
Old 10-13-2003, 05:01 AM
Danskman's Avatar
I read this thread last week knowing that I had a 2 1/2 hour drive coming up on Saturday. Crusing at 70-75mph I reached up and pushed the deflector down (80SC metal one), and it was a bit quieter, but the wind blast came down and hit me in the top rear of my head. Didn't like that at all. Tried it several times. One time I held it down for a long time, and it really bothered me. Sounds like the solution, if any, is to upgrade to the later black plastic deflector.
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 10-13-2003, 09:50 AM
