911 undercarriage
Quick question ladies and gents...
My near pristine 71 911's undercarriage is 99% perfect. The other 2% has slight surface corrosion where where fingernail size undercoating has flaked off. My question is should I go through and touch it up with something like POR15 or should I just leave it original (knowing from the Navy days that surface corrosion actually slows the corrosion process)? My car is a garage queen and the underbody will never see a liquid H20 molecule again.
Thanks.
1971 911T
Old 09-16-2003, 07:51 PM
A 71 has non-galvanized steel and rust spots should be treated.
Sometimes the old undercoating pulls away from the chassis and creates "pockets" where water/moisture sit against the steel. You won't see all the rust until the undercoating is broken off. Probably should be treated....POR15 is supposedly the trick stuff.
Scott
Old 09-16-2003, 10:56 PM
Yeah JSDSKI is right... if you see rust under there, there's probably a lot of it you don't see... And treating that one spot won't really help.
I got my car up on a lift and spent a number of very unpleasant days scraping the tar protection off the underside of the car, cleaning it, polishing it to a shine (to remove all the surface rust), zinc treating it adn then POR-15'ing it. I worry a lot less now
1968 911L
2004 Dodge Dakota SLT Plus
Old 09-17-2003, 03:29 AM
