Nothing like a 911
Targa Weatherstripping Replacement
I need to replace the weatherstripping around my Targa bar. I bought a nice clean almost new replacement from a guy on Ebay. Any tips or anything I should know before doing it? Is the best adhesive 3M? How do I clean the area after I tear out the old rubber? Any particular tool best for this? Thanks!
1982 911SC Targa 2009 Cayenne If it doesn't kill you...it makes you stronger |
be careful w/this. i had a problem b/c the extra thickness of the new weatherstripping raised the targa top slightly. this gapped the window slightly leaving more space. however, this will not likely be your problem b/c i replaced the front weather stripping also.
isaac 76 911 targa-project 91 ferrari 348-sold, broke my heart 73 vette convert-gone |
The front weatherstriping has a known issue with thickness for cars (89 and pre, I believe?). The rear seal should be fine. 3m weatherstriping adhesive is fine for this. Just be neat, it can be stringy/messy.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Senior Member
Do not attempt to drop that front weatherstripping into the channel. You MUST trim it as per instructions you can gather from Dan at CarsInc. If you don't trim the extra (provided for the later Targas that were redesigned) you risk breaking the latches when you try to snug it all down.
Do a Search on CarsInc here and gather the information you will need. John
'78 Targa in Minerva Blue |
