Heater backdate question...
...Why do it? And what, exactly, do you do?
Seriously, I know it is a dumb question, but I don't understand... |
There's a *ton* of info on this if you do a search.
Why do it? Well, for one thing, you can BBQ chickens in the passenger footwell, while you drive! (However, I think it is more of a mod for SC's and some earlier cars, than Carreras.) |
Re: Heater backdate question...
http://forums.pelicanparts.com/uploa...1064025293.jpg |
Like Doug says, there is reason to backdate an SC, even if the stock exhaust is present. Backdating gets rid of a large volume of ugly, inconvenient air plumbing in the engine compartment.
SC's aside, my post was specific to 84 to 89 Carrera's. Didn't mean to confuse you.
Why do it?
If you go to different intake, makes heat system simpler. With TWM throttle bodies or PMO carbs, there isn't a clean mount solution for the blower motor mounting. |
89911, how does the heat/defrost output after the conversion compare to the stock setup?
I just did this on my 1983SC,I added the SSI's and backdated the heat system engine tin,looks so much nicer with the fan housing and the associated plumbing gone and I have yet to try the heat,still quite toasty here in Florida!!
| All times are GMT -8. The time now is 05:31 PM. |
