Typical Fish's Avatar
Heater backdate question...
...Why do it? And what, exactly, do you do?
Seriously, I know it is a dumb question, but I don't understand...
Matt
Old 09-19-2003, 07:09 PM
Senior Member
Doug Zielke's Avatar
There's a *ton* of info on this if you do a search.
Why do it?
Well, for one thing, you can BBQ chickens in the passenger footwell, while you drive!
(However, I think it is more of a mod for SC's and some earlier cars, than Carreras.)
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 09-19-2003, 07:16 PM
Re: Heater backdate question...
Simple question. If you change your exhaust to SSI's on later model cars, the heater connection does not fit the SSI's openings. You can either a: Use several types of modifications and try to split the one blower duct coming out of the fan on top of the engine to feed the SSI's. This can only be done once it exits the one hole in the sheet metal. Then you have to do some creative thinking to try to fit these. I've done this method first and was unhappy with the materials available and the overall look in general. Or b: Recreate the old style of exiting air on both sides of the fan that flows directly through the sheetmetal and into the opening of the SSI. Simple. Clean. Functional. I've done this and I am much happier with the outcome. If you haven't changed your exhaust, there is absoulutely no reason to backdate. Maybe that wasn't explained in previous post. Gratuituos engine photo to follow
Old 09-19-2003, 07:34 PM
Senior Member
Superman's Avatar
Like Doug says, there is reason to backdate an SC, even if the stock exhaust is present. Backdating gets rid of a large volume of ugly, inconvenient air plumbing in the engine compartment.
Mocha 1978 911SC. "Coco"
Old 09-19-2003, 08:19 PM
SC's aside, my post was specific to 84 to 89 Carrera's. Didn't mean to confuse you.
Old 09-19-2003, 09:00 PM
Why do it?
If you go to different intake, makes heat system simpler. With TWM throttle bodies or PMO carbs, there isn't a clean mount solution for the blower motor mounting.
Old 09-20-2003, 07:02 AM
Green Skull 006
Jim Garfield's Avatar
89911, how does the heat/defrost output after the conversion compare to the stock setup?
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 09-20-2003, 07:17 AM
rfuerst911sc's Avatar
I just did this on my 1983SC,I added the SSI's and backdated the heat system engine tin,looks so much nicer with the fan housing and the associated plumbing gone and I have yet to try the heat,still quite toasty here in Florida!!
Old 09-20-2003, 08:14 AM
