Unidentified Electronic Component...
what is this unit that I found lurking under the passenger side kick panel?
It has various numbers on it as well as the "VDO" name...
It looks like it should be mounted, but I do not see an appropriate mounting location within the range of the travel allowed by it's wiring harness.
Old 09-23-2003, 06:51 AM
Friend of Warren
It is your cruise control module and it is supposed to be located underneath your radio.
Kurt V
Old 09-23-2003, 06:53 AM
Friend of Warren
Oh and that black plastic cover is supposed to be on the other end of the module covering the plug. You will notice a cutout on one side of the plastic cover. This is so it can slide over the cable.
Kurt V
Old 09-23-2003, 06:54 AM
thank you...
could you be a little quicker with your response next time?
That 27 second wait for this information was completely unacceptable.
